wdm
Joined: 02 Sep 2012 Posts: 14 Location: Connecticut, USA
Posted: Tue Mar 02, 2021 1:00 am Post subject: SB8R Coolant pipe corrosion |
In the process of a big bore upgrade (more to follow when I have all the parts) I found corrosion on and in the coolant pipe at the top of the pump. Might be worth a look if you have time on your hands and the bike waiting for the snow to melt.
https://ibb.co/album/qY5XM6 |
Jaguar
Posted: Tue Mar 02, 2021 2:50 pm Post subject: |
There is a mix of Suzuki and Bimota parts in the cooling system.
Take a look at my project, I had a bunch of cooling issues to sort out.
Can search on DT for more posts.
https://drivetribe.com/p/bimota-sb8r-project-bike-part-thirteen-ZpnN6HcmS6uM5pqMgBfYng?iid=QPx-CbERR4q95G9nwHK1yQ
Feel free to PM me here, or on DT if you have questions or need help.
Im in Albany, so not far from you! _________________ Bimota (Tesi 1D 904SR, DB2, DB4, SB6,SB6R, SB8R, SB8K Santa Monica) Ducati (1000SS, Monster S4, 999R) Aprilia (RSV Mille R Haga) Honda (CL125s and 70s Chopper) |
wdm
Posted: Wed Mar 03, 2021 1:10 am Post subject: |
Thanks! With the cylinders off the only issue I found so far is the pipe at the top of the pump. It is not closed but if left unattended I could imagine that it would which is why I posted for the forum. I had changed the coolant about two years ago and I think it was the first time so it looked bad. One of the tabs on the lower rad broke on disassembly. I will have a local welder do the repair.
See my comment regarding fueling in your thread. |
JennyMalin
Posted: Tue Dec 07, 2021 7:08 am Post subject: |
Yeah this is crucial.
I had not noted it though. _________________ accept | achieve |
