djt77
Posted: Thu Oct 28, 2021 1:27 am Post subject: Rear Shock for DB7 |
Before try and get a new shock, does anyone have a spring set for a 100kg rider for the rear shock for DB7 like to sell for the extreme tech type?
Alternatively if anyone has a shock set for 100kg rider from a DB7, please let me know. Otherwise looking to get an Ohlins unit, seems only way of forward at this this stage. |
Gavin944888
Posted: Fri Oct 29, 2021 1:05 pm Post subject: |
Hello.....DJT77
I have gone down this road a couple of times or three!
The MATRIS is the best out the box but never available second hand.
A used OHLINS can be found from the HONDA cbr1000rr 2009-2012...just make sure its eye and eye fitting.
I bough one of these for the DB9 (exactly the same as the DB7)....it fitted a treat and made a world of difference
I have a DB9 on a s/h Honda Ohlins....the DB11VLX on a prpoer OHLINS and a 7-11 mule using the Matris......again an ideal piece of kit and better than off the shelf Ohlins
Hope these options help and make use use the EXTREME as a door stop.
Thanks
Gavin
The Scottish Engineer. _________________ On an Island in the River Thames!
Cagiva Elefant 999r engined
Cagiva BIMOTA Motard Concept
djt77
Posted: Tue Nov 02, 2021 12:58 am Post subject: |
Hi Gavin,
Thanks your your post. I reached out to Bimota classics and they had an Ohlins that I have now purchased, lets hope it better than the original shock |
Posted: Wed Nov 03, 2021 9:42 pm Post subject: |
| Oh God...I hope its the right one...be sure to do your checks...hopefully before its posted out..... |
djt77
Posted: Wed Dec 01, 2021 7:38 am Post subject: |
Not wanting to start a new thread, does anyone have any pictures they can share of an ohlins rear shock mounted in a DB7/8.
Having purchased one, mechanic is not able to get it to fit, so its either wrong shock or something else and we aren't sure which is which. Appreciate any help. |
Bob Taylor
Posted: Wed Dec 01, 2021 12:47 pm Post subject: |
| Hi. I have an ohlins on mine. Unfortunately I cannot work out how to up load the photos. But if you can send me a contact I’ll send you them. Bob |
Posted: Wed Dec 01, 2021 1:11 pm Post subject: |
| Oh for Fucks sake.....you've gone and purchased from Paolo of BCP.....and it doesnt fit...BUT!!!!...I did warn you to check measurements before sending out....Did you tell him it was an Oro Nero with carbon swinging arm??..If so its his mistake get him to correct....if not...its your mistake as the aperture is smaller on the oror nero and the standard DB7 ohlins shock does not fit |
Gavin944888
Posted: Fri Dec 17, 2021 7:34 am Post subject: |
2Bims.........the HM Government Diplomatic office still want you back and your understanding nature....it is clear why you are so dearly missed.
Good luck DJT77 with trying to get the problem sorted......if you need any assistance...just ask
Regards
Gavin
The Scottish Engineer _________________ On an Island in the River Thames!
Posted: Fri Dec 17, 2021 3:16 pm Post subject: |
They want me back?....Oh great...I'm been getting a little bored since the onset of Winter....My bedside approach is always in demand on the terminal illness ward at Hospitals also....  |
