		| Author | Message |
		| Reaper
				|  Posted: Fri Aug 27, 2021 2:38 pm    Post subject: 2013 DB8 Bi Posto Steering Head Lift Pin Size |   |
				| Can someone please advise what size pin I need for a front headstem lift stand. It looks like it might be 22mm, but I can't get a caliper in at the right angle to measure the hole properly.
 Thanks in advance
		| Back to top |  |
		| 2bims
				|  Posted: Fri Aug 27, 2021 11:33 pm    Post subject: |   |
				| If its a folding abba stand hinged type....it won't work....as it would crush the headlight assembly during operation due to the euro pedestrian safe low swoopy light unit...i use an italian floor unit that you hand crank from underneath... |  |
		| Back to top |  |
