Tesi 3D - Front Indicator Bulb Change - Trick?
Apollo2
PostPosted: Sun Mar 21, 2021 9:54 pm    Post subject: Tesi 3D - Front Indicator Bulb Change - Trick? Reply with quote
I would like to change the indicator bulbs to some very bright LEDs in my 2008 Tesi 3D. The rear units were fairly simple. The fronts... I have removed the screws (one per indicator). I have gently pulled on the plastic lens at the screw-end and tried prying a bit at the opposite end of the lens. I even tried working both ends of the lens at the same time. Since I prefer not to break unobtainum plastic parts, I thought I would ask here.
After removing the single screw that secures the lens to a front indicator, what is the trick to removing a front indicator plastic lens in order to replace the light bulb in a 2008 Tesi 3D? Thanks in advance.
