Engine Replacement
aviator
PostPosted: Fri Mar 19, 2021 3:47 am    Post subject: Engine Replacement Reply with quote
Hi Folks,
one simple question. Can I replace the engine U712 with an U709 (GU75C)? The original engine broke and needs to be replaced.
Thanks in advance
Nicholas
PostPosted: Fri Mar 19, 2021 11:34 am    Post subject: Reply with quote
Which SB?
aviator
PostPosted: Fri Mar 19, 2021 3:51 pm    Post subject: Reply with quote
SB6
aviator
PostPosted: Sun Mar 21, 2021 4:48 pm    Post subject: Reply with quote
No one?
PostPosted: Sun Mar 21, 2021 5:45 pm    Post subject: Reply with quote
Can't recall the differing engine codes (and presumably neither can anyone else) so what exactly is the new engine your trying to fit??
aviator
PostPosted: Sun Mar 21, 2021 6:46 pm    Post subject: Reply with quote
Thank you!
It is a Suzuki GSX-R1100W yom 1995, GU75C with a serial number starting with U709. U712 seems to be the serial number for engines fitted into the SB6 originally.
I am not a Bimota expert but I have got that bike on the bench for engine replacement.
PostPosted: Sun Mar 21, 2021 8:17 pm    Post subject: Reply with quote
Yes, it looks like it can. See the bottom of this post:
http://www.bimotaforum.co.uk/viewtopic.php?p=51493&sid=1ba5bcc20abc41326e987ed3546f1d09
PostPosted: Sun Mar 21, 2021 9:58 pm    Post subject: Reply with quote
In that case the water cooled 1100 engines are all basically the same....
aviator
PostPosted: Mon Mar 22, 2021 8:29 pm    Post subject: Reply with quote
I have found a lot of spare engines but only one(!) so far having the extra mount points which seem to be mandatory on that model.
Anyway, thanks for pointing in the right direction.
If anyone can provide a suitable engine please do not hesitate to contact me Wink
Nicholas
