SB8R Coolant pipe corrosion
wdm
PostPosted: Tue Mar 02, 2021 1:00 am    Post subject: SB8R Coolant pipe corrosion Reply with quote
In the process of a big bore upgrade (more to follow when I have all the parts) I found corrosion on and in the coolant pipe at the top of the pump. Might be worth a look if you have time on your hands and the bike waiting for the snow to melt.
https://ibb.co/album/qY5XM6
Jaguar
PostPosted: Tue Mar 02, 2021 2:50 pm    Post subject: Reply with quote
There is a mix of Suzuki and Bimota parts in the cooling system.
Take a look at my project, I had a bunch of cooling issues to sort out.
Can search on DT for more posts.
https://drivetribe.com/p/bimota-sb8r-project-bike-part-thirteen-ZpnN6HcmS6uM5pqMgBfYng?iid=QPx-CbERR4q95G9nwHK1yQ
Feel free to PM me here, or on DT if you have questions or need help.
Im in Albany, so not far from you!
Bimota (Tesi 1D 904SR, DB2, DB4, SB6,SB6R, SB8R, SB8K Santa Monica) Ducati (1000SS, Monster S4, 999R) Aprilia (RSV Mille R Haga) Honda (CL125s and 70s Chopper)
wdm
PostPosted: Wed Mar 03, 2021 1:10 am    Post subject: Reply with quote
Thanks! With the cylinders off the only issue I found so far is the pipe at the top of the pump. It is not closed but if left unattended I could imagine that it would which is why I posted for the forum. I had changed the coolant about two years ago and I think it was the first time so it looked bad. One of the tabs on the lower rad broke on disassembly. I will have a local welder do the repair.
See my comment regarding fueling in your thread.
JennyMalin
PostPosted: Tue Dec 07, 2021 7:08 am    Post subject: Reply with quote
Yeah this is crucial.
I had not noted it though.
accept | achieve
