Falcolion
Posted: Mon Jul 27, 2020 4:26 am Post subject: SB8K Santa Monica Speed Sensor and speed sensor wire harness |
Hello, gentlemen
I know that SB8K Santamonica is not a most common bike around but wondering if someone can help.
I urgently need a complete Speed Sensor Wire harness that connects speed sensor to ECU (I guess). The one on my bike is a 2 wire harness.
After a long search I was able to identify a Speed Sensor used on the bike.
The Speed sensor is the one used on old Audi and VW.
The following is a list of cross-referenced part numbers which are all identical.
Rostra 501033
NTK AU0171
Standard Motor Products SC198
WVE 5S7199
I was also able to find a connector with an 8” wires.
AcDelco PT2164
SMP HP3860
SMP S697
Unfortunately connectors only come with a short 8” wire pigtails and I would have to splice and connect to build a complete wire harness.
It seems to me that a previous owner did splicing and after time connection failed.
So, if anyone is familiar with harness availability it would be awesome.
I would highly appreciate if anyone can point me in the right direction. I am 100% certain that this sensor wire harness is not unique to Bimota but don't know on what other bikes/cars it might be used on.
Also if anyone has SantaMonica I would love to see a picture of your Speed Sensor and it’s connector
Thank you in advance _________________ 2016 Suzuki GSXR750 TRACK BIKE
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
2007 Aprilia RSVR Bol D'Or
2006 Bimota SB8K Santamonica
2005 Benelli Tornado Tre
2002 Mondial Piega |
LucasJ
Posted: Tue Sep 29, 2020 1:15 am Post subject: |
Hey Falcolion,
Do you still need help with this? |
Falcolion
Posted: Tue Nov 02, 2021 7:20 am Post subject: |
LucasJ wrote: |
Hey Falcolion,
Hi, LukasJ
I changed a connector and everything worked fine for a little over a year. Unfortunately I think the actual speed sensor just started going bad. On my last ride 2 weeks ago it intermittently stopped working and my dash showed ZERO for speed and wasn't calculating miles. Then it came back to life and worked fine. It happened 3 times at least. So, I think I will be replacing the actual speed sensor.
I will post pictures shortly as well as report if everything works Ok.
I am not sure how long the weather will hold but I will definitely get it fixed before next riding season _________________ 2016 Suzuki GSXR750 TRACK BIKE
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
