Fly8s
Joined: 13 Feb 2020 Posts: 10 Location: Massachusetts, USA
Posted: Thu Feb 13, 2020 5:26 am Post subject: DB2 mirrors |
Are the mirrors 748/916 mirrors? Mine was raced so didn’t get the mirrors.
Also a source for the plastic bushings that locate the seat unit?
Thanks |
rOLLI
Posted: Thu Feb 13, 2020 7:16 am Post subject: |
Hi, ducati mirrors will not fit without modification. Search for cagiva mito mirrors.
roland _________________ DB2, DB7, DB8, YB8, Furano, YB9
916, 996 1098R, 1198SP, 900SS
F4 R312
RD350
Daytona 675R |
Posted: Thu Feb 13, 2020 9:46 am Post subject: |
| As roland says....you need flat base far mirror...not ducati 916 etc as they have a curved foot....go for far.it the manufacturer...they still sell them...2 seat fixings I fitted steel ones as the plastic heads round off if overtightened...I have a link at home I'll post up....Suzuki fixings...as the bolt size and pitch is weird |
Posted: Thu Feb 13, 2020 9:50 am Post subject: |
| 2006-7 Suzuki GSXR GSX-R 600 750 1000 Seat Bolts 09139-06146 Stainless Steel x2.....put that into ebay.co.uk.... |
Fly8s
Posted: Thu Feb 13, 2020 11:49 pm Post subject: Thanks |
| Thanks for the leads on the seat retainer and mirrors. Very helpful. Unfortunately all the special parts that make a Bimota a Bimota also make it hard to restore one if it’s not complete. |
Posted: Fri Feb 14, 2020 12:33 am Post subject: |
| The stuffs out there...usually stored on some collectors wardrobe....bedroom...loft or garage....takes time thats all...just shout up if youre missing anything.... |
Posted: Fri Feb 14, 2020 12:47 am Post subject: |
| Cant be absolute certain from the picture you emailed....but I think the previous owner swapped out the front end....none standard clip-ons....and top yoke and forks look like Paioli but seem to have preload adjusters on top and central screw for compression and rebound on the bottoms per leg.....normal DB2 forks were 41mm paiolis….with one leg for compression and one leg for rebound...and no preload adjusters on the tops...not an issue if it gives you more adjustment....Horrible wide folding US market footpegs where the pegs are out of alignment with the foot levers...BUT....if you bought new fixed footpegs....everything including the back bolt changes out and they aren't so wide then.....watch out for the suicide stand...But...there is a mod for them so it stays open unless kicked back on purpose |
Fly8s
Posted: Fri Feb 14, 2020 9:06 pm Post subject: sidestand |
| Yes, just moving the bike in the garage I need to stick my toe in the recess to get the stand out. |
Posted: Fri Feb 14, 2020 9:23 pm Post subject: |
| I use my heel.....easier to turn my foot around.....By simply making a bent alloy metal plate I moved the top fixing of the spring further forward....so kick it beyond a point and it stays out....and you have to manually retract it with your boot....I posted up dimensions and pictures on here of the mod....cost less than $1....I'll see if I can find it again |
