Posted: Fri Aug 13, 2010 9:56 am Post subject: Choke cable SB6 |
I think the choke cable on my 6 might be sticking. The bike sometimes wants to tick over at 3k, I blip the throttle and still does it then move the choke lever a bit mor "on" and it ticks over more normally.
I haven't got in there to have a look about yet, it could be the return spring on the carbs, but if it is the cable ....
Where can get a standard replacement ??? (other than Venhill) _________________ Don't read everything you believe |
husson73
Posted: Fri Aug 13, 2010 10:10 am Post subject: |
| Got the double throttle cable for my six from french bimota which hasn't it in stock and got it from factory in on week, so try Bimota uk. |
Posted: Fri Aug 13, 2010 10:46 am Post subject: |
If I recall rightly rpo83 was looking into a choke cable for his.
Give him a PM and see if he solved the problem.
We decided the switchgear was CBR so you might end up making one  |
Posted: Fri Aug 13, 2010 5:36 pm Post subject: |
I'll drop him a PM _________________ Don't read everything you believe |
