Hoses
BimotaBoy
PostPosted: Thu Oct 31, 2019 3:11 pm    Post subject: Hoses Reply with quote
Unfortunately the service is taking longer than I hoped. Done the belts and having had to dismantle half the bike to gain access I have got for the most part it back together again.
However as I have it apart I figured as the rad hoses were looking a tad old I would replace them with silicon hoses. The question is if I buy a Duke 851 premade kit, will it have all the hoses and will they fit the Tess, or should I just measure up the existing hoses and buy a load of hose and cut it to fit myself. I am worried that where there are bends that the hose will kink. Anyone been down this road.
PostPosted: Thu Oct 31, 2019 5:26 pm    Post subject: Reply with quote
I know someone that started going down that road.....and because of certain placements of engine omega plates....special hoses were needed for some places also....You may even find it difficult to find 851 hoses...when VW/Audi bought Ducati...they upgraded the computer spare parts sytems...and nothing prior to the year 2000 is listed on any of the systems anymore....Dont ever assume with a Bimota...maybe even the radiator is different...with outlets and inlets in different positions....So i'd start there and check the rad to see....Someone tried replacing a rad on a DB7 thinking Oh yeh..>Ducati 1098 radiator...Nope...different locations and feeds meaning different bends and lengths
PostPosted: Thu Oct 31, 2019 5:27 pm    Post subject: Reply with quote
If you have the Spare parts manual for the bike...look in there...Bimota used Ducati part numbers in the book if it was a Ducati part....Do you have the Spare parts manual?
PostPosted: Thu Oct 31, 2019 6:03 pm    Post subject: Reply with quote
Its "Tav20" you want on the spare parts manual and the following page gives you the code numbers
good news...Bad news....Good news is the link to the spare parts booklet is below....bad news its BCP's website and he has it linked to some horrendous cheap hosting site so its clunky and with pop ups and is steam powered...
Good News bad news
The part numbers are there, parts 16, 18, 20, 21 and 22 are rubber hoses
Bad news - the part numbers all start with 5...which means they are Bimota specific made to order and thus NOT Ducati 851 parts....as is the radiator...it also is NOT a ducati 851 part..
Good news??...they are only very short straight links...and 2 with a 90 degree bend so you should be able to find some 90 degree bend lengths available in the right diameter and just cut them to fit
https://www.sfogliami.it/flip.asp?sc=424peqo8byfamq49ustpu009dbnh325d&ID=117619#page/55
PostPosted: Fri Nov 01, 2019 12:00 am    Post subject: Reply with quote
If it's a Tesi 1 I can assure you that ALL the coolant hoses are Bimota specific.
BimotaBoy
PostPosted: Fri Nov 01, 2019 9:22 am    Post subject: thanks guys Reply with quote
thanks guys I guess I will remeasure and sit down in front of the cimputer
atomibart
PostPosted: Fri Nov 01, 2019 9:56 am    Post subject: Reply with quote
Hi Bimotaboy,
I too considered already changing the old coolant hoses of my Tesi 1 for silicone ones.
So your work could interest me and if I can be of any help...
PostPosted: Fri Nov 01, 2019 10:55 am    Post subject: Re: thanks guys Reply with quote
If you are fitting a new battery....do this now also...the bike has to be stripped to get at the battery box and remove it at the same time to get the battery out
BimotaBoy
PostPosted: Sun Nov 03, 2019 10:37 pm    Post subject: battery Reply with quote
actually you dont need to strip the bike to get to the battery just remove one panel
