PTG
Posted: Thu Sep 26, 2019 9:12 pm Post subject: Draining an SB6 tank |
Hi Guys,
As the title suggests - how is it done please? I can't see a drain hose, so what's the next best option? Where is the outlet? So many questions!
Cheers,
PTG. _________________ Regards,
Paul. |
Posted: Fri Sep 27, 2019 7:23 am Post subject: |
| Fuel tap is on the bottom right hand corner , vacuum operated , if still the original, pig to get to with the tank/seat cover still on, best to remove the cover and fuel tank and then undo 2xM5 bolts ( from memory)that hold fuel tap in. |
PTG
Posted: Fri Sep 27, 2019 2:11 pm Post subject: |
Thank you - bottom right as you're looking down sitting on the bike?
Anyone got a pic of what the tap actually looks like. Total novice here.... _________________ Regards,
Paul. |
Posted: Fri Sep 27, 2019 9:02 pm Post subject: |
If you get one of those plastic pipettes and cut the end so it will slip onto the vacuum spigot, squeeze it push it on and let go, fuel will drain from the fuel spigot.
You can also use the pipette to prime the carbs. _________________ Don't read everything you believe |
Posted: Sat Sep 28, 2019 12:34 am Post subject: |
| Or go to the pound shop and but a plastic hand pump siphon....for....a pound... |
PTG
Posted: Sun Sep 29, 2019 9:01 pm Post subject: |
Thanks Evilchicken!
| Quote: |
OK! _________________ Regards,
Paul. |
