DB2 carburator - technical details ....
rOLLI
PostPosted: Thu Sep 19, 2019 12:59 pm    Post subject: DB2 carburator - technical details .... Reply with quote
Dear all,
I'm just cleaning the carbs on my 900SS. I know all the details about that carbs, because you can find it in the web. Now I search for all details for my DB2 carbs, found nothing.
Ducati 900ss, Mikuni BDST 38 B67 :
Main Jet 140
Atomizer or Needle Jet Y-2 (ring on level 4 from top)
Jet Needle 5C19
Does anyone know the details from DB2 carbs ? Or are they completely the same ?
kind regards roland
wallaman
PostPosted: Wed Sep 25, 2019 4:48 pm    Post subject: Reply with quote
Found the following from when I had my 94 DB2 carbs apart (not sure what the specific Mikuni model is but they are identical to the ones on a 94 Ducati 900ss):
Main jet 70
Idle jet 37.5
Needle jet 119
"Diaphragm" pilot jet 1.4
The needle in my carbs and in all the diagrams I've found for a 900SS of that era doesn't have grooves for a circlip on the needles to adjust the needle height. If you want to raise the needle, you can put a small washer on the needle before you drop it through the hole in the slide. The only way I can think of to lower the needle would be to deepen the countersunk area of the slide where the needle sits.
That's all I had written down and/or remember so hope it helps.
Chuck S.
PostPosted: Thu May 21, 2020 11:24 am    Post subject: Reply with quote
Some settings that I found quite a while ago.....
PostPosted: Thu May 21, 2020 11:30 am    Post subject: Reply with quote
And this
