Crankshaft rigging
Gilles
PostPosted: Sun Aug 11, 2019 6:23 pm    Post subject: Crankshaft rigging Reply with quote
Hello bimoty friends.
I am a retired mechanic and I just took charge of a V-due to restart (stopped for 12 years).
Following a broken piston, the engine was dismantled and never worked!
It is a Dell'orto 39 carburettor model.
First surprise and first question: the two pistons go up at the same time, which seems to me illogical for a 2 cylinder engine 2 times.
What do you think ?
Thanks
Gilles
Gavin944888
PostPosted: Sun Aug 11, 2019 6:45 pm    Post subject: Reply with quote
Gilles
Absolutely correct...totally illogical unless it is the Big Bang set up....which it is.
Illogical is on the Bimota crest just below the box of frogs...in Latin.
The big bang twin firing system was introduced....I think by Cagiva ....but I could be wrong....
but,....certainly from the MotoGP 500 era
Hope this helps your rebuild project and stops you drilling another hole for the second crank pin
Good luck
Gavin
The Scottish Engineer
Cagiva Elefant 999r engined
Cagiva BIMOTA Motard Concept
BIMOTA DB11 VLX Supercharger
PostPosted: Sun Aug 11, 2019 7:37 pm    Post subject: Reply with quote
Confirmed...as Gav says....twin crank...but big bang motor...wish you luck....piston searching...hope you keep us updated....I have the full strip down workshop manuals on pdf to email if you wish...or download them for free from vdue.it
Gilles
PostPosted: Mon Aug 12, 2019 8:26 am    Post subject: Reply with quote
Thanks for those quick answers.
Ok, that's correct but illogical ..
Yes I want the workshop manuals at the following address: gilbrn@orange.fr
Gilles
Moreno
PostPosted: Mon Aug 12, 2019 6:37 pm    Post subject: Reply with quote
what was the cause of the break? it would be useful to understand the problem to prevent it from happening again .... the original pistons you will not find them anymore .... but I drive fiedler that reproduces them
PostPosted: Mon Aug 12, 2019 9:39 pm    Post subject: Reply with quote
Gilles
Click and download them all for free here from the one and only trusted source....the man that bought the company and all 320 Bimota Vdues....theres lots of manuals so click and download one by one
http://www.vdue.it/manuali.php
Weed
PostPosted: Tue Aug 13, 2019 12:14 am    Post subject: Reply with quote
When I get around to it I want to experiment with different crankshaft timings to see what differences I get with engine vibration & power
Gammaboy
PostPosted: Wed Aug 14, 2019 1:03 am    Post subject: Reply with quote
If you move away from the "twingle" timing, you'll have to re balance the cranks completely, they're not balanced the same as a single cylinder crank and the balance is out of phase because of the twin crank 90° v-twin configuration. Personally, I wouldn't bother messing with it.
Weed
PostPosted: Wed Aug 14, 2019 11:51 pm    Post subject: Reply with quote
It is a project in the future Gammaboy when I run out of projects. I have a spare motor I can rig up to an engine dyno if I want to play.
Gilles
PostPosted: Sun Oct 06, 2019 4:20 pm    Post subject: Reply with quote
Hello
After going back up the engine with love and care, I have a big problem.
I turned on and after a lot of smoke, everything was fine.
First test on the road, and after 1 km at very moderate speed, big noise and more than a cylinder works!
A ring broke and damaged the piston and the cylinder!
Where can the problem come from?
Can we find a cylinder and where?
Thank you
Gavin944888
PostPosted: Tue Oct 08, 2019 3:21 pm    Post subject: Reply with quote
Sacre Blue.....hhmmm
There are latest new cylinders and pistons available at FRP in Germany.
I know he also has some second users stock ...less monies.
I also know that he is in Crete on holiday and not back till week 43
He is a member on this forum...he is an engineer and very helpful.
Search his forum name GUIDO......based near Nurburgring
Others on here may have more and better info......but I hope that this helps
Regards
Gavin
PostPosted: Tue Oct 08, 2019 9:15 pm    Post subject: Reply with quote
Did you find the cause of the original damage and fix it? It could be the same issue.
It could have been failed big ends. The bits come up the transfer ports and wreck the top of the piston, ring and head. Did you check them?
A ring can't really break by itself. If you put the piston in backwards, the end of the ring can snag on a port and break the piston.
Do you have any photos?
Gilles
PostPosted: Wed Oct 09, 2019 4:39 pm    Post subject: Reply with quote
Hi, thanks
In fact, it is a screw and washer holding the crankshaft seal that is passed in !!!!
I do not know how to send photos
Gilles
PostPosted: Thu Oct 10, 2019 6:06 pm    Post subject: Reply with quote
Pictures need to be uploaded to a web storage account , imgur/photobucket etc and then the link pasted in the thread. If it does not work first time generally we can get to the picture and help you post it.
