DB6 O2 Sensor has permanent current and sucks battery empty
NoName
PostPosted: Wed Jul 24, 2019 8:52 am    Post subject: DB6 O2 Sensor has permanent current and sucks battery empty Reply with quote
Hello all,
the Oxygen Sensor has permanent current even with the ignition off.
Finally the battery is empty after 2 weeks.
This cant be normal, or?
Any ideas how to proceed?
Best regards,
Frank
PostPosted: Sat Aug 31, 2019 9:46 am    Post subject: Reply with quote
Disconnect the Lambda sensor if its one in the exhaust header...leave it in place but trace the wire up and disconnect it and see how it runs without it
