SB6 owners....
PostPosted: Sun May 05, 2019 10:57 pm    Post subject: SB6 owners.... Reply with quote
I’ll have the bodywork off of my SB6 for the next couple weeks if anybody needs anything checked, measured or compared. Mine is a late mark 2 and is bone stock as it left the factory.... doesn’t mean it’s the same as the bikes that were built either side of it though I guess Laughing
PostPosted: Wed May 15, 2019 3:27 am    Post subject: Reply with quote
PostPosted: Thu May 16, 2019 1:51 pm    Post subject: Reply with quote
How does the fuse box wiring go on yours ?
PostPosted: Fri May 17, 2019 12:45 am    Post subject: Reply with quote
I'm back at work now. I'll have a look next week when i'm home and post some pics if you like. Anything in particular you're looking for?
PostPosted: Sun May 19, 2019 5:59 pm    Post subject: Reply with quote
The cable route from the box connector plug to where the main loom is ... I think it's under the front subframe
PostPosted: Mon May 20, 2019 8:38 am    Post subject: Reply with quote
I'm home on Wednesday so i'll have a look
PostPosted: Fri May 24, 2019 12:52 pm    Post subject: Reply with quote
Mine runs straight down through the front subframe to a 9 pin connector (with only 8 pins in it)
Gammaboy
PostPosted: Sat May 25, 2019 3:56 am    Post subject: Reply with quote
Still the OEM brake lines there Brian?
PostPosted: Sat May 25, 2019 4:10 am    Post subject: Reply with quote
Haha yep, I knew someone would have picked that up. It’s on my to do list... you only need brakes if you want to stop anyway.
