redman412
Posted: Sun May 05, 2019 4:48 am Post subject: Rear Brake switch not turning the brake light |
Doin the maintenance before the summer, new battery in, fluids change and brakes and clutch bled, out of a sudden the rear brake doesnt turn the rear brake light when press. The front brake lever works to turn it on. Checked the connections and fuses seem all ok. Could the switch in the master cylinder gone bad? Anyone know the part number and where to get it? |
Posted: Sun May 05, 2019 10:00 am Post subject: Re: Rear Brake switch not turning the brake light |
redman412 wrote: |
What bike? Have you tested the switch? If it’s a banjo type pressure switch they are available on eBay. You need to check the thread pitch to get the right one _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Sun May 05, 2019 10:53 am Post subject: |
Redman....like Brian...what bike...so am assuming its a DB4 redBro Jap import??…..Its 99% certain its the banjo pressure switch fixed to the master cylinder...I forget the picth and thread...just checked a spare old one in the garage...its 10mm you need...but take the cap off the connecters and check for corrosion first....and then ebay 10mm banjo bolt pressure switch...Ducati dealers also stock them as they fit the brembo master cylinders for their back break lights on Ducs also |
redman412
Posted: Sun May 05, 2019 1:30 pm Post subject: |
its for a 2007 DB6, thanks for the reply, will check on it this week. |
Posted: Mon May 06, 2019 1:49 pm Post subject: |
Its easy enough to check whether its the banjo bolt pressure switch thats at fault...or the wiring.....which does lead a tortuous route and 90 degree bends and more....Carefully pull off the connecter cap on top of the unit with the black cased wiring...and connect up the two connecters on the wiring itself and turn on the ignition and see if brake light illuminates.....if it doesnt...you have a break in the wiring...if it does light up...dont forget the rear light will be on anyhow.....then its the pressure banjo switch thats at fault.....and needs replacing as its a throw away item....Any main Ducati or other bike dealer should stock them |
pkay
Posted: Tue May 07, 2019 6:14 am Post subject: |
Don't forget to check you're wiring too before you do the switch switch..... _________________ pkay
Posted: Tue May 07, 2019 9:50 am Post subject: |
pkay wrote: |
Don't forget to check you're wiring too before you do the switch switch..... |
Indeed....although its a fooking nightmare on a DB6...being a "wonderful" naked bike....the wires lead a tortuous life of 90 and 180 degree bends and twists and wraps and stuffed here there and everywhere so as not to be "visible".....leads to al sorts of issues..... |
Posted: Tue May 07, 2019 9:51 am Post subject: |
pkay wrote: |
pkay
Posted: Wed May 08, 2019 2:17 am Post subject: |
Yes my 851 is similar - and the top of the switch wires sit right where your boot is and also get caught by the rear fairing - I ended up putting those horrible blue insulated crimp fittings on because they were the only things tough enough not to break. I might make up a block terminal to provide a bit of protection while not looking like a total bodge. _________________ pkay
Posted: Wed May 08, 2019 7:06 am Post subject: |
Have you not got one of those carbon Heel guard protectors that were made up on the Forum from my Bimota original piece?....basically it bolts under the 2 bolts holding the rear brake master brembo plunger unit.....and protects the master and rear brake banjo solenoid and wiring from being scuffed by your boots.....Bimota made some as an add on piece if it was "chosen".....a neatish unit that envelopes the whole assembly |
Posted: Wed May 08, 2019 9:36 am Post subject: |
2bims wrote: |
Like this one
redman412
Posted: Sun May 19, 2019 3:00 am Post subject: |
Bought the new part, installed and still doesnt work, why? Seems my rear master cylinder took a dive and crap on me. Found it leaking while try to bleed it. No pressure at all. Anyone knows which rebuild kit to buy the 2007 DB6? |
