Posted: Mon Apr 01, 2019 3:27 am Post subject: YB10 clutch |
Dieci clutch is going. It engages at almost the point of letting out the clutch completely. I’d appreciate if someone could point me in the direction of info on clutch adjustment on the YB10. _________________ 1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
Posted: Mon Apr 01, 2019 10:54 am Post subject: |
I would start with replacing the fluid and bleeding the system. If it's still no good, check that the MC and slave are actually working properly. _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Mon Apr 01, 2019 11:05 am Post subject: |
There is no adjustment, other than bleeding.
Does the desi have a braided clutch line? If not get one.
How many k's has the bike done?
Bleed and replace the old fluid would be my starting point.
If you are going to pull it apart, plate thickness min is 2.8 mm, and get rid of the middle narrow plate and spring 9-10. They will let go. Just buy a new full plate from Yamaha, R6 plates are the same. Cheers
Posted: Tue Apr 02, 2019 6:54 am Post subject: |
Bike has about 11300 km. Not sure on type of line but will check.
Will do bleed part first.
Thanks for the info. Invaluable as always! _________________ 1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
