SB8R air filter
atomibart
PostPosted: Wed Mar 27, 2019 1:44 pm    Post subject: SB8R air filter Reply with quote
Hi,
Last Week-end I realized that the air filter's foam (above the airbox) on my SB8R was desintegrating and falling into dust in the cylinders.
So I would need to find a good replacement…
Any advice appreciated
atomibart
PostPosted: Wed Mar 27, 2019 3:13 pm    Post subject: Reply with quote
buy some filter foam and cut your own - that's what I did for my SB6.
PostPosted: Wed Mar 27, 2019 4:38 pm    Post subject: Reply with quote
I do the same with DB5/DB6 and DB4....and Vdue..."just go on ebay and search "ramAir foam filter...buy it in the size of sheet you need to make one or 2...or more....Double density foam
https://www.ebay.co.uk/itm/Ramair-Universal-Foam-Filter-Pad-600mm-x-400mm/390998061658?epid=1442346595&hash=item5b094cf25a:g:II0AAOSwofxUhvT9&frcectupt=true
atomibart
PostPosted: Wed Mar 27, 2019 5:07 pm    Post subject: Reply with quote
Thanks !
