Posted: Sat Mar 16, 2019 11:22 am Post subject: |
Oh dear... at least I know what I'm NOT doing with my other DB4  _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Sat Mar 16, 2019 11:24 am Post subject: |
At least it should tip into the corners quick with the forks lifted that high  _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Sat Mar 16, 2019 11:27 am Post subject: |
The Redbro looks very nice. _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
DB1 860
Posted: Wed Mar 20, 2019 12:55 am Post subject: |
Yeah... I'm waiting for a full faired one to turn up... hopefully after the end of this year as the govt are changing the import laws. |
Gammaboy
Posted: Wed Mar 20, 2019 3:46 am Post subject: Re: Yey????....Or Nay??? |
DB3 fork legs are longer than DB4 by about 40mm - I'd guess that's what he's done as it doesn't look overly nose down? |
fish
Posted: Wed Mar 20, 2019 5:13 am Post subject: |
I have dropped my yb11 5 mm dive into those corners in Tasmania Australia _________________ DB1-DB2SR-DB2EF-DB3-DB4 Db10 YB6-yb7_yb10-2xyb11-SB5,2xSB6-kb3-yb5-MILLE MIKEHAILWOOD HARRIS MAGMAN2-TRIUMPH T140-RG500x2-KAWA Z900-SUZUKI GSX1100-DUCATI 900SS- 750 sport ducati DUCATI F1 750- 851 tri colour-500sl-1996 Trumph datona . Vee two alchemy |
djk
Posted: Wed Mar 20, 2019 6:28 am Post subject: |
[quote="DB1 860"]Yeah... I'm waiting for a full faired one to turn up... hopefully after the end of this year as the govt are changing the import laws.[/quote]
Are you looking at the flatside one or the injected model? I have a DB4R1 and are still having issues trying to get the carbs to work properly, they are 40mm Mikuni's and we can't get them set up right as there is little to no information about them. My mechanic put on a set of CV's to see if it was the carbs and he said it was running a little lean which was expected but otherwise the bike was fine. Luckily the local importer has just brought it another bike like mine and we are going to contact the owner to see how his bike is running and if it's fine we will see what his carb set up is. |
Posted: Wed Mar 20, 2019 10:37 am Post subject: |
djk wrote: |
DB1 860 wrote: |
I’ve never worked on Mikuni flatslides, but I know Keihin FCR’s are tricky fuckers.... very difficult tune without a dyno _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
vort28-2
Posted: Wed Mar 20, 2019 2:12 pm Post subject: |
Not got Mikuni but my DB4 has got FCR's plus exhaust on it.FCR's were on it when I got it , and other than the no choke issue on starting , its run like clockwork for the last X years.
Have also ridden a CV carbed DB4 and mine back toi back and the difference the carbs make are AMAZING. Its worth getting them working properly. |
Gammaboy
Posted: Wed Mar 20, 2019 11:58 pm Post subject: |
Which variant of Mikuni Flatslide? RS40 or TMR40? (Or even TMR-MJN?) |
djk
Posted: Thu Mar 21, 2019 6:15 am Post subject: |
On the Redbro website they call them TDMR Racing carburator.
My mechanic has had his 900ss for 27 years and a 170000ish kms, he uses 41mm Keihin flatsides on his bike and knows the benefits of them so is keen to get these Mikuni's sorted.
The Mikuni's come with a choke as well. |
Gammaboy
Posted: Thu Mar 21, 2019 9:56 am Post subject: |
I lead to believe that the TDMR40’s are easier to fit to the DB4. The FCR throttle linkage fouls on the fuel tank, whereas the TDMR linkage doesn’t. The Corse Special DB4’s had a special tank made to clear the FCR linkage. _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
djk
Posted: Thu Mar 21, 2019 11:15 am Post subject: |
Thanks Gammaboy, i will pass this on to my mechanic and hopefully they can help him out.
Yes Brian you are correct, no modifications to the tank, not sure if standard airbox would fit though, this model comes with K&N pod filters from Redbro so i'm guessing the original airboxes would be sitting on a shelf somewhere or at the tip. |
