Moreno
Posted: Fri Nov 02, 2018 6:07 pm Post subject: Rpm 500 v due |
| how many rpm and set the vault 500 v two at least reggime ?? mine is about 1600/1700 rpm ..... are a bit high but unless it is not left |
BOFFER
Posted: Thu Nov 08, 2018 5:45 pm Post subject: |
| On -line translator please. |
Posted: Thu Nov 08, 2018 6:53 pm Post subject: |
I think he is asking about tick over ???
From memory mine is not much lower than that 1400ish I think |
Moreno
Posted: Thu Nov 08, 2018 10:05 pm Post subject: |
| I apologize for my English .... what I want to know is how many rpm engine your motorcycle stops ... mine has about 1600 rpm |
Posted: Mon Nov 12, 2018 1:26 pm Post subject: |
Mine was about that when I got the bike.
I left it until I had run the engine in a little and then reset the oil and reduced the rpm to about 1400 . If I stop at a junction it now ticks over about 1400 for a few minutes and then drops to about 1200rpm after that. |
Moreno
Posted: Mon May 06, 2019 8:42 pm Post subject: |
| I set the carburetor setting of the minimum bike now the bike from cold remains on without 1300/1400 rpm ... but the engine is beautiful when warm, the mimimo rises to 1800/1900 .... to you the minimum is even higher with a warm engine? |
