vDue regulator.
2Tspirit
PostPosted: Fri Apr 13, 2018 12:52 pm    Post subject: vDue regulator. Reply with quote
Hi all.
One question: do you know what regulator/rectificator does the VDue fit? And do you know how to test it? Mine doesn't charge the battery.
Thank you!
AF1, SV650, 500 Vdue, GSX-R 750 SRAD
PostPosted: Fri Apr 13, 2018 1:04 pm    Post subject: Reply with quote
Ive had 2 on my bike go now, first time I replaced with like for like from Piero , this time I got a new one, thick moffet one, think its a Ducati st2. (not fitted my new one yet.
Helmers
PostPosted: Tue May 01, 2018 5:05 pm    Post subject: Re: vDue regulator. Reply with quote
2Tspirit wrote:
Hi all.
Thank you!
I think the regulator is Ducati ST2!
RG500, TZR500, Vdue, Suzuki Polaris 800, Bmw HP4, 1098S, Gsx-r1000, RSV Mille R, R1, RGV250, RS250, TDR250..
Helmers
PostPosted: Tue May 01, 2018 5:06 pm    Post subject: Re: vDue regulator. Reply with quote
2Tspirit wrote:
Hi all.
Thank you!
PostPosted: Tue May 01, 2018 5:39 pm    Post subject: Reply with quote
If its a Ducati item and one for an ST2....I've bought from Electrex in the past to replace Ducati units.....and they have been more reliable
I see that they use Mosfet electronics in their units also
http://www.electrexworld.co.uk/acatalog/RR50.html#SID=439
steff_dk
PostPosted: Tue May 08, 2018 10:37 am    Post subject: Reply with quote
I had a look in the manual and noticed is says connecting a battery charger can damage the regulator. Not sure if that could be a contributor ...
PostPosted: Tue May 08, 2018 11:25 am    Post subject: Reply with quote
Yeah 2bims, thats the one I got, just got to fit it now.
Not seen that before steff, thanks for the heads up although don't tend to charge batteries on bikes or use trickle charges as they kill batteries also.
Did notice that the new one does say not to use with Lithium batteries !! So maybe that helped my previous ones demise as my vdue runs a lithium battery, or maybe its something particular to electrex mosfet ones????
