neil
Joined: 25 Apr 2016 Posts: 10 Location: Tucson (Arizona - USA)
Posted: Thu Feb 15, 2018 3:54 am Post subject: SB8R Tail piece mounting rubbers |
Does anyone have a source for these? They’re the top hat shape ones under the Allen key on seaf unit.
Plus the lower fairing mounting rubber grommets? They’re getting a little perished.
I’ve tried Bimota classic parts and graf-de but neither has got back to me. Part numbers below.
I was also looking for a rearset guard (LH) from the RS rearsets as mine has a small crack....
1. QTY=3 Part No. 214000055 - passacavo (seatunit rubber), TAV Number - 12
2. QTY=2 Part No. 212000016 - silentblock (fairing lower rubber), TAV Number - 34A
3. QTY=1 Part No. 505170620 - protezione (peg guard)*, TAV Number 27A
*I have rearsets from the RS model, so I’m not sure if this is the correct part?
Any help appreciated!
Thanks
Neil |
wdm
Joined: 02 Sep 2012 Posts: 14 Location: Connecticut, USA
Posted: Sat Mar 03, 2018 9:01 pm Post subject: |
For Part No. 214000055 - passacavo (seatunit rubber), TAV Number - 12
I used NAPA Part Number NOE 7701306
Rubber Grommet Dorman Products Inc 7/8 I.D. in.
https://www.napaonline.com/en/p/NDP7701306
Not an exact fit but pretty close and definitely works. I assume the original is metric.
HTH - Whit |
neil
Posted: Tue Mar 13, 2018 7:44 pm Post subject: |
Thanks Whit & 2Bims, they worked a treat. Hadn't actually removed one to check what it was, hadn't thought it was a grommet.
All sorted now.
Neil |
