mickgrim
Joined: 29 Apr 2011 Posts: 6 Location: 216 Northampton
Posted: Fri Feb 16, 2018 2:22 pm Post subject: SB8R radiator |
SB8R
Has anyone got any information on which manufacture the bottom radiator was sourced from or where I could get 1 from thanks. _________________ SB8R owner and loved most of it.
Now DB9 & bonded
3 bims Jota 180 zx6 track bike & a grom |
daotoys1
Posted: Thu Mar 15, 2018 8:27 pm Post subject: |
FYI .... the original SB8R/S bikes had only the 2 side radiators. The lower 3rd radiator was added to assure enough cooling for street use ( where stop & go adds temp )
I had 3 SB8RS bikes . 2 of them i used in the colorado mountains aggressively ( over 50k miles ) with the 3rd lower radiator removed . Not a single over heat even in stop & go ...
However , i added a manual override switch to turn fans on as needed
no problem
just something to ponder
by the way , KTM made the OEM rads for my 3 SB8RS bikes
good luck
Posted: Fri Mar 16, 2018 2:30 pm Post subject: |
When I was at the London bike show I saw a stand by West Mercia Radiators. He makes both radiators and oil coolers.
It might be easier to get something custom / bespoke for the bike than to waste to much time looking. They might be able to make a thicker rad with more capacity rather than bigger.
http://www.westmerciaradiators.co.uk/motorbike_radiator_repairs.html _________________ Don't read everything you believe |
pilegoteam
Posted: Tue Mar 27, 2018 1:00 pm Post subject: |
The third radiator was built by IRIA and not by KTM ( like the others..) ...but now the factory is closed.
So you have to contact the bimota classic to ask them a brand new...if they have!
I don't know but if you don't live in the middle of a big city the third radiator is not necessary.
Best regards
Alex _________________ Pilego TEAM |
