Oil Change
BimotaBoy
PostPosted: Sat Jun 03, 2017 7:56 am    Post subject: Oil Change Reply with quote
How the fudge are you supposed to change the oil, or even top it up, on an SB6? The only way you can get to the filler cap is if you drop the motor.
I was thinking of fitting one of those Goodridge fittings on the filler hole with a length of hose and a fitting with a cap on the other end but now I'm not sure that there is enough room for the fitting. Anyone fitted one or does anyone have any ideas
SiBag
PostPosted: Mon Jun 05, 2017 11:10 am    Post subject: Reply with quote
Just use a length of hose and a funnel..
And fill it slowly.
Si...
PostPosted: Mon Jun 05, 2017 4:48 pm    Post subject: Reply with quote
Lol its like force feeding huh ☺
If you can't get the oil filler out then use the engine breather, put a hose and funnel onto it.
PostPosted: Tue Jun 06, 2017 12:09 pm    Post subject: Reply with quote
I was able to remove the filler plug on my SB6 using a ball end Allen key.
