fish
Posted: Fri Mar 25, 2016 6:19 am Post subject: spare parts wanted |
Hi all I have a set of Tecnomagnesio wheels on my yb6 .As the speedo has never worked and have brought gauges- speedodrive and cable to sort the problem out. Found that speedo drive had seized and has destroyed the drive ring for the speedo drive.Does anybody know who sells parts for these wheels cheers fish PS I work away from home and parts come up for sale before I checked it out _________________ DB1-DB2SR-DB2EF-DB3-DB4 Db10 YB6-yb7_yb10-2xyb11-SB5,2xSB6-kb3-yb5-MILLE MIKEHAILWOOD HARRIS MAGMAN2-TRIUMPH T140-RG500x2-KAWA Z900-SUZUKI GSX1100-DUCATI 900SS- 750 sport ducati DUCATI F1 750- 851 tri colour-500sl-1996 Trumph datona . Vee two alchemy |
Posted: Fri Mar 25, 2016 11:13 am Post subject: |
Have a look at the remains of the drive ring, you can find its thickness if nothing else. Measure the drive to find the size of the lugs and do the same for the wheel.
Find a lazer cutting company and get a ring done.
This is based on the ducati type drive ring being cut from thin flat steel _________________ Don't read everything you believe |
fish
Posted: Wed Mar 30, 2016 5:11 am Post subject: spare parts wanted |
Hi thanks for advice evilchicken.Have found parts as they all are standard Yamaha parts cheers fish _________________ DB1-DB2SR-DB2EF-DB3-DB4 Db10 YB6-yb7_yb10-2xyb11-SB5,2xSB6-kb3-yb5-MILLE MIKEHAILWOOD HARRIS MAGMAN2-TRIUMPH T140-RG500x2-KAWA Z900-SUZUKI GSX1100-DUCATI 900SS- 750 sport ducati DUCATI F1 750- 851 tri colour-500sl-1996 Trumph datona . Vee two alchemy |
Posted: Wed Mar 30, 2016 9:28 am Post subject: |
That's a result  _________________ Don't read everything you believe |
