bimota injectors
mortsta
PostPosted: Sun Mar 21, 2010 12:11 pm    Post subject: bimota injectors Reply with quote
hi,
trying to find out who and where the injectors on the sb8r were made?
thanks
morty
PostPosted: Mon May 17, 2010 1:25 pm    Post subject: Reply with quote
try to find a Suzuki TL1000S tuner .... there was an article in Performance Bikes magazine recently.
mortsta
PostPosted: Sat Jul 03, 2010 5:10 am    Post subject: Reply with quote
thanks mate...
kb11110cc
PostPosted: Wed Jul 07, 2010 2:48 pm    Post subject: Reply with quote
THEY ARE DEF NOT SUZUKI
NOTHING LIKE THEM, AND A DIFFERENT SIZE
MUCH LARGER.
KB1
SB8R Tuner
PostPosted: Tue Nov 30, 2010 5:06 am    Post subject: Reply with quote
The injectors in the SB8R are made by Webber. They are the same as in the Ducati 748, 916, 996.
daotoys1
PostPosted: Tue Nov 30, 2010 5:22 pm    Post subject: Re: bimota injectors Reply with quote
mortsta wrote:
hi,
thanks
morty
The Throttle Bodies are 59mm ubits made for BIMOTA are are not found on any other vehicle .
The injectors are 6 BAR single units horizontal within the TB ( Throttle Body) and are made by Webber Morelli as is the ignition system.
The ECU is made for BIMOTA by MicroTech and is BIMOTA SB8R/SB8RS specific.
The Suzuki TL cylinder heads are match ported to accept/fit the 59mm TBs that BIMOTA has on the SB8R/SB8RS and Gobert replica.
The BIMOTA SB8K Santa Monica uses completely different 52mm Throttle Bodies with ECU controlled "tilting" shower type injectors unique to the model only.
I hope this helps.
Smile
SB8R Tuner
PostPosted: Tue Nov 30, 2010 6:43 pm    Post subject: Reply with quote
Just correct a couple of things datoys1 wrote. Not trying to stomp on any toes but just want the right information to be stated.
The ecu is made by Magneti Marelli for the Fiat 500 series and was configured to work on the Tl1000 motor for Bimota. Microtec tuned the ecu for Bimota. The TL heads on the SB8R are the same as on the USA TL1000r bikes and are not port matched.
atomibart
PostPosted: Thu Jul 16, 2015 12:05 pm    Post subject: Reply with quote
Hi,
I guess the Weber Marelli fuel injectors for the SB8RS have the reference IWP069...Anyone could confirm ?
Can those injectors be cleaned in ultrasound bath ?
Thanks,
atomibart
atomibart
PostPosted: Tue Jul 21, 2015 10:43 am    Post subject: Reply with quote
...Or may it be that the SB8 RS uses Weber IW724 fuel injectors ?
Not easy to find this kind of info...
atomibart
sb8rs
PostPosted: Fri Sep 11, 2015 12:59 pm    Post subject: Reply with quote
Sorry just read the thread.
I can confirm on the SB8rs the injectors are Webber IW724's
They are usually found on all 4v 888 ducati's.
Information via my mechanic.
atomibart
PostPosted: Tue Sep 15, 2015 8:08 am    Post subject: Reply with quote
Thanks sb8rs
I love this forum...loads of good informations here
My SB8's fuel injectors need to be ultrasonic cleaned...or maybe replaced
atomibart
