YB11 Lower Fairing Mounting - Help with pics please
Falcolion
PostPosted: Sat Jan 30, 2016 9:47 pm    Post subject: YB11 Lower Fairing Mounting - Help with pics please Reply with quote
I was wondering if anyone can share some pics of how the the lower fairing is mounted on the back side. Because the fairing that I had had some cracks and some extra holes drilled I got my painter fix it up and possibly the holes either got closed up or might be of the wrong diameter.
If anyone can snap a clear picture of the rear of the lower fairing, bolts, rubber grummets and spacer if they exist, as well as how the are connected between each other and the bike I would highly appreciate it Basically if you can point the camera from the rear wheel facing forward I would be able to see which bracket(s) are utilized and then from the bottom of the fairing so I can see how many actual holes are there.
In any case any and all info with pics will be extremely helpful
Thanks in advance
Vlad
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
2007 Aprilia RSVR Bol D'Or
2006 Bimota SB8K Santamonica
2005 Benelli Tornado Tre
2002 Mondial Piega
PostPosted: Sat Jan 30, 2016 11:09 pm    Post subject: Reply with quote
Are you talking about the Belly pan or the middle two panels of the side fairing?
Do you have the workshop manual? Figure 2-2 on page 4-2 shows clearly holes and bolts or clips and what goes where...I can email you the relative pages if you pm me your email addie.......
Basically the nose cone comes off...then then mid panels which are also fixed to the Horses Yoke collar for want of a better phrase...then the belly pan is held in place on its own with other brackets and screws at the bottom that hold the 2 halves together......Search Ebay.de or I will post on here...as theres a german seller who has the panels for sale showing holes etc etc
http://www.ebay.de/itm/Bimota-YB11-original-Verkleidung-links-unten-unlackiert-ab-Bj-98-/400618763627?hash=item5d46bd356b:g:5tUAAOxyXDhSnMje
http://www.ebay.de/itm/Bimota-YB11-original-Verkleidung-vorne-Mitte-schwarz-ab-Bj-98-/400618764034?hash=item5d46bd3702:g:IVMAAOxy63FSnMkJ
http://www.ebay.de/itm/Bimota-YB11-original-Verkleidung-rechts-Mitte-unlackiert-ab-Bj-98-/400618763792?hash=item5d46bd3610:g:-MIAAOxy3zNSnMju
http://www.ebay.de/itm/Bimota-YB11-original-Verkleidung-vorne-Mitte-unlackiert-ab-Bj-98-/400618764140?hash=item5d46bd376c:g:KRAAAOxypNtSnMkY
http://www.ebay.de/itm/Bimota-YB11-original-Verkleidung-links-oben-unlackiert-ab-Bj-98-/400859471581?hash=item5d55161edd:g:9b0AAOxy3zNSnMjT
Falcolion
PostPosted: Mon Feb 01, 2016 7:16 am    Post subject: Reply with quote
Bims
All I need is to see the actual clear pictures of the holes sizes on the back of the lower fairing/Belly Pan as well as which way bracket(s) are mounted
The diagram in the Parts Manual on Page 78 out of 86 (TAV. 32/A) shows the following parts
32970301 Bush (spacer)
259907002 Rubber pad
These parts are supposedly mounted in the right side Lower Fairing in the 1st rear hole that is father from the rear wheel
Also the following diagram shows only one bracket (black in the picture and on the diagram with exhaust. And Parts diagram are showing the opposite way to the way it's mounted on my bike. I also have another bracket that is not on a diagram with the shock.
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
2002 Mondial Piega
