Falcolion
Posted: Sat Jan 30, 2016 9:47 pm Post subject: YB11 Lower Fairing Mounting - Help with pics please |
I was wondering if anyone can share some pics of how the the lower fairing is mounted on the back side. Because the fairing that I had had some cracks and some extra holes drilled I got my painter fix it up and possibly the holes either got closed up or might be of the wrong diameter.
If anyone can snap a clear picture of the rear of the lower fairing, bolts, rubber grummets and spacer if they exist, as well as how the are connected between each other and the bike I would highly appreciate it Basically if you can point the camera from the rear wheel facing forward I would be able to see which bracket(s) are utilized and then from the bottom of the fairing so I can see how many actual holes are there.
In any case any and all info with pics will be extremely helpful
Thanks in advance
Vlad _________________ 2016 Suzuki GSXR750 TRACK BIKE
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
2007 Aprilia RSVR Bol D'Or
2006 Bimota SB8K Santamonica
2005 Benelli Tornado Tre
2002 Mondial Piega |
Falcolion
Posted: Mon Feb 01, 2016 7:16 am Post subject: |
Bims
All I need is to see the actual clear pictures of the holes sizes on the back of the lower fairing/Belly Pan as well as which way bracket(s) are mounted
The diagram in the Parts Manual on Page 78 out of 86 (TAV. 32/A) shows the following parts
32970301 Bush (spacer)
259907002 Rubber pad
These parts are supposedly mounted in the right side Lower Fairing in the 1st rear hole that is father from the rear wheel
Also the following diagram shows only one bracket (black in the picture and on the diagram with exhaust. And Parts diagram are showing the opposite way to the way it's mounted on my bike. I also have another bracket that is not on a diagram with the shock.
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
