NAPPE
Joined: 26 Feb 2012 Posts: 22 Location: Tampere Finland
Posted: Mon Jan 12, 2015 9:55 pm Post subject: Bimota sb 6srew |
I ned help this parts???
pult 14*1,25 mm (5st) back weels |
Posted: Mon Jan 12, 2015 11:03 pm Post subject: |
Do you have a picture of it ? _________________ Don't read everything you believe |
NAPPE
Posted: Mon Jan 12, 2015 11:45 pm Post subject: |
| Evilchicken0 wrote: |
| Do you have a picture of it ? |
How do I add a picture to the message??? |
Posted: Tue Jan 13, 2015 1:17 am Post subject: |
| Size wise sounds like Cush Drive pin bolts for the back wheel?? |
Hursty
Posted: Tue Jan 13, 2015 1:39 am Post subject: |
Is this pic of my back wheel any help?
 _________________ Hursty from kiwi land  |
NAPPE
Posted: Tue Jan 13, 2015 7:24 am Post subject: |
| Hursty wrote: |
YES!! |
NAPPE
Posted: Tue Jan 13, 2015 1:00 pm Post subject: |
My Bimota wheels is Bimota .I ned this type only pult??? |
Posted: Tue Jan 13, 2015 1:11 pm Post subject: |
Bimota used different wheels for the SB6, I think the Mk 1 is a dymag H section type (as above ^^^)
Mine is Mk 2 with Marchesini
The later MK2 used Antera wheels. _________________ Don't read everything you believe |
NAPPE
Posted: Tue Jan 13, 2015 2:55 pm Post subject: |
That early early Mk 1 B6 wheel...branded "bimota" is referred to as the oscom wheels....and the part you need is indeed the Cush drive pins....they were known to shear/snap on early models....same wheels used on Db2.....Contact Rudolf at Bimota-parts.de.....he makes these bolts specifically to order....I bought a set from him and the cush drive rubbers and collats (metal sleeves) for my Db2...
Read half way down on here....and you will see the parts and German words for the parts from Rudolf
http://www.bimotaforum.co.uk/viewtopic.php?t=1196&start=0 |
