Riding again!!
PostPosted: Tue Nov 18, 2014 6:39 am    Post subject: Riding again!! Reply with quote
For the first time since Sept. 27th I rode my 'mota today! The cast came off of my hand last Wed. and could not stand it any longer! Sliding into my leather jacket felt so sweet, and putting a couple of miles on the bike just felt soon good
Spike C.
1965 Triumph T100SC
PostPosted: Tue Nov 18, 2014 10:04 am    Post subject: Reply with quote
Nothing better than some good news in the morning!!!
Enjoy😃
PostPosted: Tue Nov 18, 2014 10:57 am    Post subject: Reply with quote
Cool - take it steady and do the physio
PostPosted: Tue Nov 18, 2014 11:54 am    Post subject: Reply with quote
Congrats spike...and yeh...take it easy and physio is most important...presumably you've thrown the damaged parts back on for your ride until Italy shakes into action for your new spares?
PostPosted: Tue Nov 18, 2014 8:16 pm    Post subject: Reply with quote
Good to hear Spike, nothing like a waiting Bimota to hurry the healing process up.
Is the 5R repaired now ?
PostPosted: Wed Nov 19, 2014 12:48 am    Post subject: Reply with quote
Right now I have a "Road Warrior" model DB5. It works just dandy, and when the panels finally show up from Italy I may install them!
Does anyone know if it is a good idea to clear coat bare aluminum?
Spike C.
1965 Triumph T100SC
PostPosted: Wed Nov 19, 2014 11:15 am    Post subject: Reply with quote
Clear coating/lacquer to metal? I'm no painter but in my cases where I've tried, whether it be polished steel or alloy...is a lack of adhesion for the lacquer in that it flakes off VERY easily...even when cured properly.......theres just not enough roughness in the metal surface to give the lacquer something to hold onto like it would if the surface was roughed over first....but then you wouldnt want to rough over a polished metal surface if you were lacquering it.....Speak to painters though as it may be just the lacquer I've used......It would seem that most if not all mainstream bike manufacturers choose not to coat alloy that has a smooth finish.........The likes of Ducati that have sandcast alloy actually choose to paint it....but all milled/honed alloy...or polished alloy tanks are usally left bare.
Is it the tank that you are thinking of?
PostPosted: Wed Nov 19, 2014 12:08 pm    Post subject: Reply with quote
If the ally is polished properly it shouldn't need a lacquer. Proper buffing mops seal or pleen the surface then put the shine onto it. You'll need to polish it again, maybe once a year to take the oxidisation off.
My SB6 frame and swingarm are polished
PostPosted: Wed Nov 19, 2014 1:29 pm    Post subject: Reply with quote
Those are fair points.......I also use "alumagic"...a metal polish for alloys, copper, brass and stainless steel........you rub this in and leave for a few minutes for the wax to harden...and then buff to a high polish....and the hardened wax leaves a protective coat to give at least 3 months protection against tarnishing, rain spots etc.......other products are available
PostPosted: Wed Nov 19, 2014 6:53 pm    Post subject: Reply with quote
I use a buffing mop on a drill - you only need the finishing polish
Yes, 24bims, it is the tank of which I speak. It has a fairly rough surface, as it appears to not have been quite finished. I am smoothing the surface with abrasives, I need to start at 60 to 80 grit! I am a bit Leary of over sanding as I do not know how thick the material is, but I suspect that I have nothing to worry about.
The Japanese makers habitually clear coat over their polished engine cases, so it is possible. I think that I will rely on a bit of wax once I have reached the finish that I am happy with.
This tank was reportedly purchased from the company that was making them for Bimota, I am wondering if maybe this was a prototype. Either that or the order was canceled just before the thing was done!
Thanks for all the input!
Spike C.
1965 Triumph T100SC
PostPosted: Wed Nov 19, 2014 7:41 pm    Post subject: Reply with quote
Might be worth having a look at the Ducati Panyless superleggra has a painted and alloy tank, but don't know if it is all larquered over or just left bare. Might give you an idea if possible or not.
PostPosted: Wed Nov 19, 2014 8:08 pm    Post subject: Reply with quote
Not sure if that particualr tank is alloy or steel...it is lacquered though...but the finish underneath is a satin grained look which would aid adhesion.........
PostPosted: Wed Nov 19, 2014 8:24 pm    Post subject: Reply with quote
Might be worth having a look at the Ducati Panyless superleggra .
Don't you mean "Pantyless"?
Spike C.
1965 Triumph T100SC
PostPosted: Wed Nov 19, 2014 10:28 pm    Post subject: Reply with quote
Pantyless it is , but got a bit excited Confused
