tee849
Joined: 03 May 2013 Posts: 23 Location: NE Lincolnshire
Posted: Fri Apr 11, 2014 12:53 pm Post subject: SB6 headlight |
Having a bit of a tidy up and want to change one of the headlights of mk1 sb6.
Does anybody know which bike they came from? It says Stanley 5729 on the lens. The closest I have found is from an rc29 but the mount is wrong.
At the same time I am changing the plastic mounting bracket which is held together with a piece of number plate to a machined alloy one. Can't see it but I know it's there.
Thanks
Duncan _________________ Zzr1400 , 916 Senna, SB6 crescent
Never regret. |
Spring
Joined: 16 Nov 2010 Posts: 106 Location: South Coast UK
Posted: Fri Apr 11, 2014 3:10 pm Post subject: |
Seems original headlights are swooped for zxr400/gsx400
Units. ...see more ,  |
Posted: Fri Apr 11, 2014 4:39 pm Post subject: |
The lights changed between Mk1 and Mk2, the Mk1 has smaller dia than the Mk2.
I don't know which bike the Mk1 is from but the zxr / gsxr sounds familiar. You could measure them, look for a replacement and make a mount for the new lamps _________________ Don't read everything you believe |
Bimsb6
Posted: Fri Apr 11, 2014 9:55 pm Post subject: |
| Cagiva elefant is the unit fitted to the mk2 not sure about the mk1 , |
Posted: Sat Apr 12, 2014 12:39 am Post subject: |
Might get some info here-
http://www.bimotaforum.co.uk/viewtopic.php?t=2190&postdays=0&postorder=asc&start=60 _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Sat Apr 12, 2014 12:41 am Post subject: |
And also here -
http://www.bimotaforum.co.uk/viewtopic.php?t=3448 _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
tee849
Posted: Mon Apr 14, 2014 6:17 am Post subject: |
Thanks all,
Got one from Kawasaki for the ZXR. It's a different mount but I can change that.
Never regret. |
Posted: Tue Apr 22, 2014 10:33 am Post subject: |
| tee849 wrote: |
Thanks all,
Duncan |
If you have finished the lights.
We are always interested in pictures.  _________________ vince
tee849
Posted: Fri May 09, 2014 8:13 pm Post subject: |
Hi,
Got the new bracket now and an extra light. How do I add photos?
Thanks
Duncan[/img] _________________ Zzr1400 , 916 Senna, SB6 crescent
Never regret. |
tee849
Posted: Sat May 17, 2014 8:34 am Post subject: Before and after |
Here is the before and after of the headlight change.
One lens changed, rewired and a new mount.
http://photobucket.com/albums/y307/tee849/headlight%20change
Thanks to cymarc for the bracket, great engineering.
Never regret. |
Posted: Sat May 17, 2014 12:11 pm Post subject: |
That's pretty much how mine look. If you find they fit tight because the lamps are bigger at the back then undo the coolant expansion tank. _________________ Don't read everything you believe |
Posted: Sat May 17, 2014 1:50 pm Post subject: |
looks good ....
nice aluminum plate.  _________________ vince
Posted: Sun May 18, 2014 12:57 am Post subject: |
Nice work
