Bimota DB4ie engine?
polyesterpig
PostPosted: Tue Feb 11, 2014 3:50 am    Post subject: Bimota DB4ie engine? Reply with quote
After working on the throttle bodies, I realized that the injectors were the brown band ones found on the 900mie Monsters, not the green injectors found on the 900ssie? The brown injectors flow a bit more than the green injectors, so the ecu has to have a different map. Are the cams the same on the injected monsters and super sports? I'm guessing that the injected DB4s actually came with Monster motors, not Super Sport motors.
2002 Cannondale E440
(3) 2003 Cannondale E440R
2000 Bimota DB4ie BiPosto
macchiman
PostPosted: Thu Feb 13, 2014 10:30 pm    Post subject: Reply with quote
When I managed to break the electrical connection off one of my DB4ie injectors my local auto injection specialists matched it up with one from a Fiat Panda car, Weber part WFI024. Didn't quite match the exotic image of a Bimota Smile
Bimota DB4ie
Ducati Paso 750
Aermacchi Ala Rossa 250
Parilla Wildcat 250
Neracar 1922 221
Corona
PostPosted: Fri Feb 14, 2014 8:40 pm    Post subject: Reply with quote
WF 1024 is the number for the injector, I had to buy a replacement for mine a few years ago after the bike developed a bit of a misfire. It's a 4 port nozzle as opposed to a single port for a standard 900ss, got it from WEBCON http://www.webcon.co.uk/ very helpful and quick post about £90 ish. The fuel tank is very close to the horizontal cylinders injector and the connector on mine had developed a crack. Not sure what else the injector fits but the electrics do have something in common with an early Fiat Panda car Embarassed
polyesterpig
PostPosted: Sun Feb 23, 2014 12:55 am    Post subject: Reply with quote
Corona,
Since I have my bike apart, I took a look at the injector location. You are right, the air box is resting on the rear injector. Whipped out my heat gun and heated the plastic area on the air box and pushed it in a little. Now the air box doesn't touch the injector.
Idea
PostPosted: Mon Feb 24, 2014 12:17 am    Post subject: Reply with quote
polyesterpig wrote:
Corona,
Idea
Nice work Wink
