Rear Caliper Model (wheel cylinder)
sbbimota
PostPosted: Tue Dec 31, 2013 6:24 pm    Post subject: Rear Caliper Model (wheel cylinder) Reply with quote
Does anyone one know what Brembo model caliper is on the rear? I think its a model P32b, but the guy I spoke with says that model has only one inner sealing ring and mine has 2.
peter
pete
SB8R Tuner
PostPosted: Tue Dec 31, 2013 7:59 pm    Post subject: Reply with quote
There is usually a seal ring along with a dust seal. Is that what yours has?
sbbimota
PostPosted: Tue Dec 31, 2013 8:20 pm    Post subject: Reply with quote
I have no dust seal, but have two seal rings as I mentioned. It looks just like the P32b
pete
SB8R Tuner
PostPosted: Tue Dec 31, 2013 9:15 pm    Post subject: Reply with quote
Is the seal closest to the pad thinner, (from top to bottom) than the other seal?
PostPosted: Tue Dec 31, 2013 9:16 pm    Post subject: Reply with quote
The outer seal is the dust seal the inner is fluid seal
sbbimota
PostPosted: Tue Dec 31, 2013 10:29 pm    Post subject: 2 seals Reply with quote
see photo...two seals....anybody got a repair kit...no longer available from anywhere on the net that I can find.
https://www.dropbox.com/sc/bul35bqsybuo1hz/ObzxFSXphu
Peter[/img]
pete
SB8R Tuner
PostPosted: Tue Dec 31, 2013 10:54 pm    Post subject: Reply with quote
I see one dust seal, (closest to pad) and one pressure seal. I would measure the seal sizes and check on some of the jap bikes that have the same size pistons. That design is widely used in the jap bike market.
bimota_rider
PostPosted: Thu Jan 02, 2014 10:19 pm    Post subject: Reply with quote
Hey Peter,
I may be out in left field here but, I think the entire brake package on your SB6R was lifted directly from the Ducati 996 of the same year; rotors, calipers, pads, master and rear brake cylinders.....the whole shebang....
Built 5/97
2014 Suzuki Hayabusa
2001 BMW R1100S
PostPosted: Thu Jan 02, 2014 11:53 pm    Post subject: Reply with quote
Apart from the rear disk and all the Bimota discs are iron rich
sbbimota
PostPosted: Sun Jan 05, 2014 7:11 pm    Post subject: new rear brake caliper Reply with quote
well folks…due to the wonderful world of litigation…you can't get a kit or rubber square rings to fix your caliper from Brembo…i did however find a replacement caliper for the bike from cyclebrakes.com…nice guy out here in california…about $100.
btw…the major leak occurred at about 110MPH through wine country…nice puff of smoke like james bond mobile as the wheel sprayed the brake fluid onto the silencers!
pete
PostPosted: Sun Jan 05, 2014 10:28 pm    Post subject: Reply with quote
Aren't they fitted to KTMs who would do a seal kit ???
