Posted: Wed Dec 11, 2013 9:30 pm Post subject: New Pipes! |
My new set of cat-less Zard pipes just arrived! Hoo-Dee-Hoo!!
Now I need to decide whether to ceramic coat them, and if so what finish to use. _________________ Spike C.
1965 Triumph T100SC |
waggytee
Joined: 16 Nov 2013 Posts: 54 Location: Shropshire, UK
Posted: Thu Dec 12, 2013 4:30 pm Post subject: |
You can't un-wrap them until Christmas day remember
Any chance of before and after photos for an aesthetic comparison? |
Posted: Thu Dec 12, 2013 8:19 pm Post subject: |
Too late on the unwrapping part! I can take before and after pics, butt the only difference will be the lack of the little beer can midway down the front pipe.
2bims has a thread over on the "Bimota Chat" forum called ceramic coating by camcoat that shows the whole thing quite nicely!
I am leaning heavily on forgoing the coating as the new pipes match the end pipes so well. _________________ Spike C.
Posted: Fri Dec 13, 2013 10:05 am Post subject: |
Heres the thread of before and after for Cam Coat...which should be available in the US as its a patented system that the company I use in the UK bought a license from the US company to do....the pipes do polish up nicely as standard without camcoating if you see there is evidently a difference but still all nice and shiney...even the x-piece shines up nicely as the standard system is SS...just not polished finish...evidently it would brown and golden with use...which is kind of nice also |
waggytee
Posted: Fri Dec 13, 2013 12:20 pm Post subject: |
Thanks for the link to 2bims thread - very interesting. |
Posted: Sat Dec 14, 2013 3:11 pm Post subject: |
Spike,
congratulations for purchase! If you will not go for ceramic coating at least you should polish them otherwise they get that unattractive brownish look. Steve's ceramic coat looks excellent quality and adds function (heat transmission).
Another thing... Zards take a few miles to run in ant then they get right sound.
Enjoy! _________________ Bimota DB7, Bimota DB5 Mille, Ducati 916, Ducati M900, Benelli Tornado Tre |
Posted: Sat Dec 14, 2013 4:20 pm Post subject: |
CNC wrote: |
Spike,
Enjoy! |
You shouldnt have this problem though spike...as you are keeping the existing Open Zard end cans...that are actually titanium on the DB5R...whereas CNC purchased a full system with the squished carbon end cans...unfortunately I could not compare which was loudest at the TT as CNC had a flattish battery and didnt want to risk draining it totally just to start it up to please my ears....He is right though...new cans take a while for the baffle material to get coated and they absorb less sound
Posted: Mon Dec 16, 2013 12:53 am Post subject: |
I couldn't stand it and went ahead and installed the pipe(s) today.
Guess what? In accordance with Standard Bimota Practice (SBP), there was no cat in the midpipe! Only in the front header! I ended up just using the one pipe and none of the 7 springs that they sent!
It is noticeably louder now, sort of like an engine with straight pipes! _________________ Spike C.
Posted: Mon Dec 16, 2013 9:22 am Post subject: |
Sounds more than "standard" for Bimota...although maybe a previous owner pulled the cat out of the x shaped collecter as that would be quite easy to do as at least theres access from both ends when its off the bike...middle Cat on front header is a different bag altogether....hopefully it will help running issues also as evidently the front cylinder would have been choked until up to temperature when compared with the Cat free rear cylinder...Have you found that starting is a little easier?
And nice one with finding a set of springs and spring puller in your Zard Box...I'll now have to root through mie and also see if there were similar items...as I simply pulled the pipes out and didnt sort through the squidgy packing stuff... |
Posted: Tue Dec 17, 2013 12:56 am Post subject: |
2bims wrote: |
Hope you haven't thrown it out  _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Tue Dec 17, 2013 11:54 pm Post subject: |
Ok, it does seem to start easier, and it definatly runs better, at idle and in the previously ragged 3-4 k range.
It sounds like a jalopy now though! _________________ Spike C.
Posted: Wed Dec 18, 2013 11:38 am Post subject: |
Standard Ducati Jalopy sound...glad to hear that you are noticing a difference...was never keen on the irratic starting and initial running until warmed up....that all magiacally dissappear after the cats are removed thankfully...keep an eye on the brass plugs in the headers for tightness....I had a couple of initial runs and all fine...and then whilst trying to keep up with my friend on a Vdue....a hopeless task....I experienced a sudden exhaust note change like an end can had fell off...turned out one of the brass plugs in the rear header had worked itself loose and gone walkabout...wouldnt have thought it would make such a difference... |
Posted: Thu Dec 19, 2013 8:48 pm Post subject: |
Well now, I was worried about the jalopy sound so I pulled the body panel off and..........
The new rear head pipe came with the brass plug installed, and I didn't bother to really look at the front one, being all excited about the lack of the cat, and just installed it. It seems that the front pipe did not have the brass plug!
I removed it from the old pipe and installed it in the new, and now it sounds like a proper hotrod and not a jalopy! _________________ Spike C.
Posted: Thu Dec 19, 2013 9:57 pm Post subject: |
Strange how. Things go eh? And it was the only pipe you fitted....typical italian quality control eh? Check and check again, or in itaky, eat pasta, dtink wine, job done...  |
