TESI P FOR GRABS
MARTIN
PostPosted: Fri Oct 25, 2013 8:01 am    Post subject: TESI P FOR GRABS Reply with quote
Up for grabs over on
http://raresportbikesforsale.com/emotion-technology-2008-bimota-tesi-3d/
lots of photos
look at the one for the shock passing between the header pipes,that must be one hot shock Surprised
Remember to wipe the screen when finished Laughing
Marty
(00) SB6 (95) HD FXDWG STRETCH (01)GSXR1000K1
PostPosted: Fri Oct 25, 2013 9:58 am    Post subject: Reply with quote
Tis nice...and maybe one day...The rear Shock set up is standard and the same on the Db5 and Db6 as they have the same rear swinger set-up...part of the reason why I camcoated my headers and pipes to protect the rear shock. Not such an issue on the Db5R as they have an Ohlins with remote unit, which is mounted upside down compared to the extreme Tech shock so at least the remote res is further away from the exhaust pipes. Mind you that creates the issue that you cant adjust it unless the seat unit is off...or you wait for when the headers are cold as you can reach it by putting your arm through the gap between the 2 pipes....not to be done evidently when hot...Only Bimota...either way is a bit messed up
