Joergen76
Joined: 31 Aug 2013 Posts: 5 Location: Bergen, Norway
Posted: Fri Oct 04, 2013 9:30 am Post subject: Yb9 fork rebuild? |
Hi all.
I have a yb9 with rsu 43 forks that are leaking. The former Bimota dealer in Norway says that these forks need a total rebuild after 10000 km if ridden hard. Mine has 19000 on it and as far as I know it has been abused the last 13000. I asked Bimota-teile.de and they gave me a price on oil and dust seals, but not a word about bushings and o-rings. Any thoughts about this?
Do I need a rebuild or will the seals do the trick? I have never ridden the bike, but the previous owner (my neighbour) says they were fine when he parked it five years ago.
Regards,
Joergen _________________ 98 YB9, 99 YZF-R6, 75 KH500, 77 GT380, 83 CX650, 94 JAWA350 |
Posted: Mon Oct 07, 2013 3:48 pm Post subject: |
Hi Joergen, Just my opinion okay?
Pull them apart and check bushing play, replace the seals.
Forks and shocks should be serviced like all other mechanical components. Assess, inspect, and then take appropriate action. Quite often oil change is all that is required (unless seals are leaking)
We change our engine oil every whatever km's. but leave our rear shock in place for 20 years...lol. Cheers,
Ralph |
bimota_rider
Posted: Tue Oct 08, 2013 4:06 am Post subject: |
Try this first, But rather that using this special tool, use a high quality PAPER business card.
People will show you how to use other products, like film, or plastic cards, but those can rip or cut your seals. If you use them properly and keep them tight against the fork tube, film or plastic cards can work, there is just a bit of a risk involved.
Using the paper card also has its risks, such as, the card tearing because it became too soggy with oil.
You only want to make one circular pass with each paper business card, then repeat with a new card two or three times.
I fixed my leaky seals on my SB6R with Paoli RSU 43s on it, with this method.
http://www.youtube.com/watch?v=8wlzfoVroSY
. _________________ '98 Bimota SB6R #000016 "Sweet 16"
Built 5/97
2014 Suzuki Hayabusa
2001 BMW R1100S
Joergen76
Posted: Thu Oct 10, 2013 4:42 am Post subject: |
Thanks for the input guys. New problem: Opened the fork today. It does not look like the pictures in the owners manual i found on the web. When i take the top off, there is no spring there. The spring has to be somewhere further down. How do i get the spring out? And loosen the cartridge? Measuring Oil level? I have serviced forks before, but this is new to me. Any help would be appreciated.
Posted: Fri Oct 11, 2013 12:50 am Post subject: |
Are the forks still in the bike ?
If they are like the rsu46/51mm forks the seal carrier is a seperate piece. Remove the dust seal and the seal circlip and you will be able to tap the seal carrier down the fork lower rather than have to undo the cartridge.
Also with the fork out and the cap removed the slider should just drop into the fork lower to show the spring. |
Joergen76
Posted: Fri Oct 11, 2013 8:48 am Post subject: |
The forks are off the bike. I can slide the inner tube all the way down, but still no spring. There is a washer there with four holes in it. it probably holds the spring down. i will look at the seal carrier tomorrow. If it goes down maybe i can see whats under it. The reason i want to open it is that i only got out maybe 100 - 200 cc of dirty oil. Im afraid there is a lot of crap in the bottom. I dont think flushing it would be enough. Anyone who knows how much oil there is supposed to be in there?
