		| Author | Message |
		| bob
				|  Posted: Tue Aug 06, 2013 11:04 pm    Post subject: sb6 Clutch Slave Cover |   |
				| Dear Forum,
 Does anyone make a replacement/modified clutch slave cover for the sb6.  Mine seems to move quite a bit and the clutch drags - I would be interested in buying a solution. Anybody help please? Thanks. Bob.
		| Back to top |  |
		| Evilchicken0
				|  Posted: Tue Aug 06, 2013 11:32 pm    Post subject: |   |
				| Check the bolts are done up. Then check the sprocket cover isn't fractured. Race Engineering used to make a cage for them but generally Bimota cut a little too much of out of the cover. You might need to find another cover and recut it ... but you have to drop the engine to fit it.
 Have you changed the clutch line ?
		| Back to top |  |
		| Vince186
		| Back to top |  |
		| bob
				|  Posted: Thu Aug 08, 2013 9:23 pm    Post subject: |   |
				| Thanks for the tips. Got in touch with Race Engineering - going to send him some photos and hopefully get a part made. Cheers. Bob. |  |
		| Back to top |  |
