sb6 bolt size
alanv
PostPosted: Sun May 19, 2013 1:29 pm    Post subject: sb6 bolt size Reply with quote
hi all, I have frame protectors fixed to the top motor mount ,if I remove these compleat with the long bolts I will need to replace with std size, any idea what size these are ? thanks AL
PostPosted: Sun May 19, 2013 6:20 pm    Post subject: Re: sb6 bolt size Reply with quote
I can not visualize how your frame protectors are mounted.
Therefore, it is my not clear which bolt you mean.
Can you make a picture.
A picture says more then thousand words. Wink
vince
PostPosted: Sun May 19, 2013 8:03 pm    Post subject: SB6 Bolt Size Reply with quote
I'm pretty sure they're M10 x 40 fine pitch.
alanv
PostPosted: Sun May 19, 2013 9:28 pm    Post subject: Reply with quote
HI vince, photo not possible at the moment, so in less than a thousand words here goes, the bolt size I need is for the cylinder to frame mount hidden behind the black grommet halfway up the frame rail cheers AL HI jonny, thanks for the info I"ll give your bolt size a go, cheers AL
PostPosted: Sun May 19, 2013 10:48 pm    Post subject: Reply with quote
Get one of these from Pro-Bolt
http://www.pro-bolt.com/workshop-other/tools/pro-gauge-bolt-measuring-tool-essential-item-for-tool-box.html
alanv
PostPosted: Sun May 19, 2013 11:16 pm    Post subject: Reply with quote
HI evilchic I'm unable to use the gauge, as the bolts I need have been replaced with overlength bolts which hold the nylon crash protectors in place, I think VINCE is right, a picture may be required . thanks AL
CBar
PostPosted: Fri May 24, 2013 11:48 pm    Post subject: Re: SB6 Bolt Size Reply with quote
This is it.
[/img]
PostPosted: Sat May 25, 2013 10:14 am    Post subject: Reply with quote
Measure the threaded shaft not the bolt head. Although, if you measure the shaft and ad 4 (generally) you'll get the AF or spanner size
alanv
PostPosted: Mon May 27, 2013 4:43 pm    Post subject: Reply with quote
cheers evilchic. just the job mate.
alanv
PostPosted: Mon May 27, 2013 4:50 pm    Post subject: Reply with quote
thankyou cbar. spot on pictures, cheers AL
