jtl
Posted: Sun Mar 03, 2013 9:47 am Post subject: Sb6r fuel bulb. Or float |
Ran out of fuel yesterday. Very embarrassing calling my dad at my age to bring me a can of fuel.
Anyway it's either the bulb or float stuck. But I do think bulb. The bulb doesn't light up with first turn of the key as the oil light does. My question to all is what's the best way to access the bulbs without stripping half the bike down. There maybe a really easy way. Thanks for everyone's help. Off to France and Spain end of may so really need the fuel light. |
Posted: Sun Mar 03, 2013 10:39 am Post subject: |
I really hope it's the bulb for your sake. The fuel senders on these bimotas are known to fail. Not sure about the 6r but both senders on my sb6 and db4 are cactus. I don't think anyone has found a compatable replacement yet. I'm no help with the 6r dash sorry.
... oily? _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Sun Mar 03, 2013 11:47 am Post subject: |
You can test the bulb by taking the wires off the float sender and shorting them then see if the bulb lights.
You'll need the top fairing off to get to the clocks I expect _________________ Don't read everything you believe |
Posted: Sun Mar 03, 2013 6:07 pm Post subject: |
The light won't come on like the oil light when you turn on the ignition anyway (as long as there is fuel in the tank).
Bulbs are dead easy to replace on the 6R clocks
You should now toss a coin to decide if you should have the tank off first to check the sender or test the bulb first. Both should take no more than 30 minuets. your time starts now, Good luck  _________________ SB6 mk1 (project mega light, big bore)
