jtl
Posted: Sat Dec 08, 2012 5:37 pm Post subject: Gear failure at 100mph |
Decided to take the sb6r out for a short run to mainly to keep the carbs from sooting up. Whilest on a dual carriageway and approaching a set of lights at nearly a ton I decided to brake and go down thru the box but to my horror at first down change I had no control over the lever. Typical Italian bolts was the fault. The Allen nut that connects the lever had decided to rattle itself loose and disappear. Managed to stop ok with brakes and at side of 70 mph road nick the rear brake Allen bolt and get back home. Plus side is the rear brake still worked a touch.
Moral of story check those Italian bolts more regularly and carry the Allen keys. |
Posted: Sat Dec 08, 2012 5:41 pm Post subject: |
...or replace the Italian bolts with real bolts and use a touch of thread lock
..Glad it turned out OK  _________________ SB6 mk1 (project mega light, big bore)
Posted: Sat Dec 08, 2012 9:08 pm Post subject: |
Just something to keep you interested  _________________ Don't read everything you believe |
