Bimota sb 6srew
NAPPE
PostPosted: Mon Jan 12, 2015 9:55 pm    Post subject: Bimota sb 6srew Reply with quote
I ned help this parts???
pult 14*1,25 mm (5st) back weels
PostPosted: Mon Jan 12, 2015 11:03 pm    Post subject: Reply with quote
Do you have a picture of it ?
NAPPE
PostPosted: Mon Jan 12, 2015 11:45 pm    Post subject: Reply with quote
How do I add a picture to the message???
PostPosted: Tue Jan 13, 2015 1:17 am    Post subject: Reply with quote
Size wise sounds like Cush Drive pin bolts for the back wheel??
Hursty
PostPosted: Tue Jan 13, 2015 1:39 am    Post subject: Reply with quote
Is this pic of my back wheel any help?
Hursty from kiwi land Smile
NAPPE
PostPosted: Tue Jan 13, 2015 7:24 am    Post subject: Reply with quote
YES!!
PostPosted: Tue Jan 13, 2015 10:45 am    Post subject: Reply with quote
There are crush drive rubbers on the Bay
http://www.ebay.co.uk/itm/Dymag-rear-wheel-cush-drive-rubbers-set-32-x-16-x-11-damper-set-/201257482314?pt=UK_Motorcycle_Parts_13&hash=item2edbe1784a
My Marchesini rear wheel uses allen bolts and the rubbers fit over them, similar to this
http://www.ebay.co.uk/itm/Ducati-749-999-Rear-Sprocket-Carrier-for-Marchesini-Wheel-/121522897801?pt=UK_Motorcycle_Parts_13&hash=item1c4b544389
NAPPE
PostPosted: Tue Jan 13, 2015 1:00 pm    Post subject: Reply with quote
My Bimota wheels is Bimota .I ned this type only pult???
PostPosted: Tue Jan 13, 2015 1:11 pm    Post subject: Reply with quote
Bimota used different wheels for the SB6, I think the Mk 1 is a dymag H section type (as above ^^^)
Mine is Mk 2 with Marchesini
The later MK2 used Antera wheels.
NAPPE
PostPosted: Tue Jan 13, 2015 2:17 pm    Post subject: Reply with quote
Bimota -pats catalogen
http://www.bimota-parts.de/images/PDF/Catalogo_Ricambi_SB6-SB7.pdf
TAV 27
12A 500981030
PostPosted: Tue Jan 13, 2015 2:55 pm    Post subject: Reply with quote
That early early Mk 1 B6 wheel...branded "bimota" is referred to as the oscom wheels....and the part you need is indeed the Cush drive pins....they were known to shear/snap on early models....same wheels used on Db2.....Contact Rudolf at Bimota-parts.de.....he makes these bolts specifically to order....I bought a set from him and the cush drive rubbers and collats (metal sleeves) for my Db2...
Read half way down on here....and you will see the parts and German words for the parts from Rudolf
http://www.bimotaforum.co.uk/viewtopic.php?t=1196&start=0
