Kojay
Joined: 03 May 2008 Posts: 21 Location: Bonnie Scotland
Posted: Wed Jan 21, 2009 6:20 pm Post subject: SB6R firing order |
Hi Guys, Just started up the bike there and it is running like a bag of spanners. Checked the downpipes and it isn't running on No.1 & No.3. Are these cylinders shared on the same ignition coil?
The last time I had the bike out it started on 3 then chimed onto 4 cylinders after a couple miles. Does the SB6R use the same shite Suzuki coils as on the GSXR's? Every Gixer I have had the coils have started to break down. Does the SB6R use 3.0 ohmn colis?
Cheers Kojay  |
Posted: Thu Jan 22, 2009 9:44 pm Post subject: |
Yep, 3ohm coils and NO, 1and 4 from a coil, 2and 3 from the other coil. Very important you've got the right feed to each coil, i.e. they are not interchangeable. Got a couple of pairs of coils here if you get stuck
oh yea, wheres my wiring diagram you promised  |
