miriman
Posted: Sun Jan 29, 2012 4:11 pm Post subject: SB6 Fuel Tap |
| Can someone suggest which fuel tap works on the SB6? Thanks in advance. |
Posted: Sun Jan 29, 2012 4:33 pm Post subject: |
Take it you don't have a fuel tap?.........
The original fitting for the SB6 is a duel outlet vacuum operated tap manufactured by Paioli.......
...If you find a source, please share as I'm also in need of one  |
Posted: Sun Jan 29, 2012 8:19 pm Post subject: |
[img]http://paioliammortizzatori.multimodo.com/img.asp?linee=2&modello=2157105&lang=en&img=/prodotti/img/Upl-11-1-008.JPG[/img]
Ever seen one of these before ????
Anyway moving on, what's up with your tap ? has the nut holding it on lost it's thread ? _________________ Don't read everything you believe |
miriman
Posted: Sun Jan 29, 2012 10:23 pm Post subject: |
| Thanks for your help guys. I have a tank but the fuel tap that came with it doesn't fit. I thought I had read somewhere that the standard tap wasn't that good and to replace it with something else. I was hoping a Suzuki tap might work, but I guess there is probably a space problerm. |
andyxxdiane
Posted: Wed Feb 08, 2012 7:26 pm Post subject: |
Hi the link from vort28 is spot on, that is what I fitted to mine.( Just remember to blank off your vacuum pipe from the manifold.) Reaching it is OK once you are familiar with where to reach for it up the back of the seat from underneath . PS watch that exhaust (HOT) Oh and try to remember which way is ON / Reserve and OFF.
Andy |
miriman
Posted: Wed Feb 08, 2012 10:45 pm Post subject: |
| Thanks for that guys. I'll order one and the list of parts needed gets shorter and shorter. |
