Posted: Tue Nov 29, 2011 2:14 pm Post subject: |
oily wrote: |
give me screaming over rattling anyday |
Still running the standard full steel cover on the clutch casing and hidden beneath bodywork so not so rattly, and yeh Ok the valves and tappets also may make a noise but only at standstill, after which the Keihin FCR41 flatslides take over, with the induction from the K&N air filter cones sitting nicely under the tank cover doing their best Darth Vadar impersonation, after which the Corse titanium straight through cans take over
That said I may be getting to the age whereby ear plugs may be used, after a good hour or so apparently I can't hear a word that the Misses says to me, and always blame it on the bike |
MARTIN
Posted: Tue Nov 29, 2011 2:27 pm Post subject: |
When my missus moved out a few years ago I did not know what to do
But now I realise where all her clothes and shoes used to be gives me space to store all my Bimbo bits
Try not to bash them with the hoover though _________________ Marty
Posted: Tue Nov 29, 2011 2:37 pm Post subject: |
MARTIN wrote: |
Similar to myself, but seeing as she cleared the garage out also when she went (why would a woman want a Black & Decker Workmate?, let alone gardening tools!) I realised there was space to be filled and indeed now it is, seem to be wealthier also |
Posted: Tue Nov 29, 2011 9:00 pm Post subject: |
fantastic result, good luck.............. |
Posted: Tue Nov 29, 2011 9:23 pm Post subject: |
great write up so far Steve - keep it coming! |
Posted: Tue Nov 29, 2011 9:31 pm Post subject: |
GeeKay wrote: |
heloo Garry and welcome back, you've evidently been busy working again, or reading old motorbike magazines?.
When are you "springing" your surprise? And for what reason? |
Posted: Wed Nov 30, 2011 9:35 am Post subject: |
Thanks for the tips on the laquering, I must give it a go, I've had a 'new' carbon mudguard for the Superlight for 4-5 years now and not got around to it!
Can I ask who the YB when to then? is it all done?
not a bad morning todasy for the last ride on my Mille before it stays in the garage for 3 months, pity Bimota never used the dry sumped Rotax engine because it's a cracking lump, dry sumped, no belts, good fuel injection _________________ 03 YB11, 03 Aprilia RSVR Edwards, 94 Ducati Superlight III, 95 Honda NC30, 04 Ducati 999S, 91 kawasaki KR1-S C2, 91 Ducati 851 USD Strada, 89 ZXR750H1, 90 ZXR400H1, 205 16v Rally Car, A6 2.7TDI Avant, STM R1 engined Phoenix |
Posted: Wed Nov 30, 2011 10:30 am Post subject: |
philfingers wrote: |
not a bad morning todasy for the last ride on my Mille before it stays in the garage for 3 months, pity Bimota never used the dry sumped Rotax engine because it's a cracking lump, dry sumped, no belts, good fuel injection |
When trying the lacquering just remember that it won't look its best after you've lacquered it, only after its hardened and you've flatted it back down, either with a500-a800 wet and dry used with soapy water or high grade t-cut laboriously applied evenly in nice cicrcular motions. Then followed by a quality polish again, buffing wheels are also good.
YB11 went off to Vort, so it stayed in the North, was sort of sorted, even though forks were done, one went AWOL again, Vort sorted that, but it has a fuelling problem, can run fine, although darn thirsty, then coughs and chokes and refuses to start, gives him something to do at the weekends... |
Posted: Wed Nov 30, 2011 11:42 am Post subject: FURTHER UPDATE |
Well the bike was now running, coughing a little whilst still reawakening her inner spirit, not revving fully and a few little lights here and there were intermittent as to whether on or off or just flickering. It had been some 8 years since electric last flowed through them. New belts were ordered, heaven knows how old the previous ones were, I had records of them being changed in '98 but evidently nothing after that. The backing plates at the back of each top pulley on each cylinder were perished, hence a new pair were ordered, horizontal cylinder not a problem, easy access, top cylinder though needs the Top engine mount taking out to tilt the engine forward to get to the back of it. The parts aren't particularly "integral" to the running of the engine, but the captive sockets for the cam belt covers are held in the rubber casing, thus when perished they just turn and pull the rubber, so best to change.
Indicators were mismatched so new ones ordered, thank Goodness for Ducati spare parts being plentiful the world over, full set of 4 picked up for 20squid
Bought from this guy on ebay, nice enough fella, quick delivery, lots of Ducati parts.
Nice fellows at Ducati Mcr, recommended that I fit a new regulator/rectifier. They were amazed that the bike still had its original one fitted as they were known for overcharging and blowing your battery up consistently or overheating, shutting down and then draining your battery down. Evidently as I had never run the bike I wouldn't know
Old one out
And new One in
And seeing as they were nice guys at the shop they recommend I get one from Electrex as they are better than Ducati ones (shh don't tell anyone, they'll get into trouble)
So a new RR51, arrived the day after ordering, UK supplied stock
To be honest, the location that Bimota have for it to fit is not great, they have cooling fins on the back, yet they fit it iside the nose cone, well away from any passing wind current when riding. But at least the new regulator has 11 cooling fins on both side to disperse heat, whereas the old one only had 7, and only on one side
The Front brake master cylinder had been changed some time ago for a serie d'oro (strange how you start to become fluent Italian) "gold series" for those with less fluency, whereas the clutch master cylinder was the old black coffin box Ducati stndard item. Seeing as only one was original, and the seals could be AWOL a replacement serie d'oro clutch master cylinder was procured with remote reservoir, gives a smoother action, balances and matches the right side, and the old black series was slated by testers as being a cost saving as serie d'oro was available in 93/94 but not used, well this bike was the "cheap" bike of their production run at the time.
New belts arrived and were fitted but seemed too slack, old ones had been thrown away so mild panic as no check could be given as to length of new compared to old. Good ol boys at Ducati Mcr cut old belts off and then tied them to the bike for reference, but some other OCD possessed individual thought it made the bike look messy and threw them away. To be frank they didn't know what had been done to the engine by the previous owner, other than the big bore kit, change change etc, but later discovered that the belt tensioners had lost their tension over the years of being stood idle, 2 New ones were ordered, 90 squid, Ouch, but sorted the problem, nice to have new anyway, there was some wear and tarnish on the rollers anyhow.
Valve clearances checked and adjusted, new Oil and filter, including fuel, evidently all new fluids for brakes and clutch to go with the new calipers, mounting bolts, pads and discs and tyres. Ooo Err....time for its first MOT in over 8 years. Well it was after I had to go done to the shop to help the guys fit the rear stainless steel heat shroud.
Its a two piece sheet steel Chinese puzzle affair, to be fitted loose, turned around in the right direction fitted upside down first then swivvelled throiugh 180 with the rear sub frame off.
All the bodywork was dropped off, after many many applications of T-cut and polish, together with mirrors, guards, indicators, with all new SS bolts to fit in lieu of old, fresh from Spalding Fasteners, nice quick delivery and cheap as buttons, but good finish, perfect for non stress related points.
A new tinted screed was bought from Skidmarx to preserve the original, some 65squid, budget ever extending, but nice that they still stock them.
When the screen arrived I rapidly opened the box to check fitment, and Doh...No holes drilled in screen. The captive "nut" on the back of the fairing for the screen bolts is part of the fibreglass faitring and simply threaded, for a teeny tiny 4mm bolt. New screen was taped into position and with a very slow speed drill and special pointy drill bit, new holes were drilled in the correct locations. Old screen can't be used as a template as they won't sandwich together due to the double curvature.
All parts fitted and Shop rang to say it was ready for its MOT, after fitting a new banjo brake light switch for the rear brake light that was Inop
I was fairly busy at work that day, but additionally realised that perhaps it was time to insure the bike! The chance of the first ride was given to the shop, all 400 yard to the MOT station and back again. Lets face it, they would be insured and could take the chance of riding, I find that I'm not too sentimental on that front.
Like an expectant father I waited for the news, concerned over the straight through Corse cans....Phone rang, and Yeh, she's passed, no worries over the noise, bloke at the garage has to deal with all Ducatis that come from the shop, so is fairly used to it. Oh and by the way they tell me, the speedo isn't working, but don't worry, its not an MOT requirement to have a working speedo, its only illegal to actually speed, as opposed to not knowing if you are speeding. New speedo cable ordered, another 9.99 although not bad considering as it included the casing and not just the inner
Bike was still not ready for collection though, Reason? Seeing as MOT's were now electronic linked to a central database, the bike didn't appear on the system as it had been sorned for so long, thus I had to take the V5 down to the station so they could enter the details manually and produce a nice fresh new MOT certificate, matching my new Insurance certificate courtesy of Footman James, 220squid fully comp for the DB2 and YB11, including breakdown and european cover. One advantage at least of getting older and buying older bikes
Posted: Wed Nov 30, 2011 12:00 pm Post subject: |
My eyesight is not as good as it used to be.................
Do the speedo/tacho have "Bimota" anywhere on the faces? |
Posted: Wed Nov 30, 2011 12:41 pm Post subject: |
Fortunately, as you may say, no they do not have Bimota written on them, white faced, which is standard, but they say Veglia, as they are standard veglia italian made clocks, exact same as was used on Ducati 900SS at the time, and for later models such as 888's/851's, Superlights, although the latter of those had a Oil temperature gauge also. The Bimota addition to the clocks being a nice carbon fibre wrap around the sponge casing of the 2 clocks and idiot lights, that extends around the side a little rahter than just a stick on piece. Fortunate, as I say, that they are easily located on the 2nd Hand market, due to Ducatis being broken, speedo and Tacho are both mechanical cable driven, and the back lighting are simply pull out bulbs. I do have a spare set of triple white faced veglia clocks to later retro fit a temperature gauge to the instrument panel, for another day.
All switch gear, wiring, fuse box, rectifier, clocks etc were straight same as used by Ducati, plentiful supply, with no Heath Robinson design |
Posted: Wed Nov 30, 2011 12:46 pm Post subject: |
Is this how they came out of the Bimota factory? |
Posted: Wed Nov 30, 2011 1:59 pm Post subject: |
Same as my Superlight III, with exception as you say to the carbon fibre face instead of the period foam! _________________ 03 YB11, 03 Aprilia RSVR Edwards, 94 Ducati Superlight III, 95 Honda NC30, 04 Ducati 999S, 91 kawasaki KR1-S C2, 91 Ducati 851 USD Strada, 89 ZXR750H1, 90 ZXR400H1, 205 16v Rally Car, A6 2.7TDI Avant, STM R1 engined Phoenix |
Posted: Wed Nov 30, 2011 2:00 pm Post subject: |
Yes indeed, a straight buy from a supplier, and fit, other than the carbon wrap which is a bit of a con, as it actually adds weight, but looks better than the black sponge surround that is beneath, and greys and fades with age.
Missed a trick at MOT time, due to it being so long since it was MOT'd there were no records on the system, and I could have fitted any old speedometer with a lower mileage, but what the heck, kind of an honest guy, and have previous MOT's for it and sorn notices for the previous 8 years to back up what is there
DB4's also had straight "rip-off" clocks as fitted to 750/900Ssi.e's not to mention 748/916 etc, so again an easy repalcement item, although they have black faces, green illumination as opposed to white faces, white illumination,
Posted: Wed Nov 30, 2011 2:13 pm Post subject: |
Same as my Superlight III, with exception as you say to the carbon fibre face instead of the period foam! |
That would be a superlight IV then? seeing as the first was the first and the Mk 1 was the second, it makes the 3rd the 4th, are you still with me?. Always wanted one, although happy to make do with the DB2 instead
Still makes me laugh that they called it a Superlight, shaving 7 kilos off from a standard 900SS, mostly by not fitting rear footpegs and hangers, and a carbon front guard and clutch cover. Yet the DB2 at the time itself was again 7 kilos lighter than the Superlight, where from? Engine same, exhausts longer, trellis frame, plastic tank, yeh, must help a bit, but the rest.
Albeit, still want one,(But would have to be the original, in yellow, white frame with Marvic wheels) if yours is yellow post up a pictue please Phil, just for me, if red, Ah what the hell go on, although they are slower I believe... |
