Carb Settings for Jolly Moto's
Goto page Previous  1, 2, 3
mick
PostPosted: Mon Nov 25, 2019 3:12 pm    Post subject: Carb settings for jolly Moto pipes Reply with quote
Hi, DQ258 sprayer does exist Dellorto.co.uk (Eurocarb) have three in stock.
Gasoline in the air box is usually caused by float bowel flooding check float levels possibly renew needle valve assembly....you will have to check the size before you order.
To adjust fuel level turn carb upside down gently press float bowel arms to close fuel supply.....the arms should be parallel with the carburettor body with 3mm clearance +/- 0.5mm
Eurcarb stock all dellorto parts .....next day delivery to uk maybe longer to eu.
PostPosted: Tue Nov 26, 2019 12:46 pm    Post subject: Reply with quote
And this is the Link...Micks your man for setting carbs on Vdues....turned mine into a pussy cat easy rider....with still the extreme rocket ship to Mars acceleration from 7thou to the skies...infinity and beyond (Buzz Lightyear)
https://www.dellorto.co.uk/
Moreno
PostPosted: Tue Dec 10, 2019 1:34 pm    Post subject: Reply with quote
2 bis quale set hai per jolly moto ?
PostPosted: Tue Dec 10, 2019 2:05 pm    Post subject: Reply with quote
THese are for jolly Moto Carb Vdues....English please...theres no auto Translate on here...
Questi sono per jolly Moto Carb Vdues .... inglese per favore ... non c'è auto Traduci qui ...
Moreno
PostPosted: Tue Dec 10, 2019 8:25 pm    Post subject: Reply with quote
2 bims which setting did you use for jollymoto carburetors? the setting that provides piero seems to be rich, I think we can do better
Page 3 of 3
