Posted: Thu Apr 04, 2019 4:27 pm Post subject: |
| Moreno wrote: |
I see youre also running a threaded rod through the rear spindle with cotton reel bobbins on the end so you can use with a rear pop up stand...One of the later Vdues? With SB6 front forks and yokes and black carrier front discs....when Piero was running out of parts to complete bikes...? I never recall...is the swingarm with no cotton bobbins the SB8 swingarm...or is it the vdue one original with swingarm bobbins already on the swingarm???
Oh Welcome Back Vort28...father of Vort 28-2....has RLJ blocked Vort 28-2 but now you can get back on with Original Vort?? |
Moreno
Posted: Tue Apr 09, 2019 11:24 am Post subject: |
| the swingarm is of the 500 v two model ..... the front shock absorbers are original 500 v two with 40 mm calipers ........ the last 500 v two assembled by piero have 65 mm calipers the black disks are brembo but I also have the new ones to keep with care |
Moreno
Posted: Tue Apr 09, 2019 11:28 am Post subject: |
here are images of 500 v two with amortized with 40 mm clamps |
Moreno
Posted: Tue Apr 23, 2019 8:44 pm Post subject: |
This is my creation to remove the clutch cover more easily without having to use the sealing paste
Posted: Tue Apr 23, 2019 11:09 pm Post subject: |
Did you make the gasket yourself? _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Moreno
Posted: Wed Apr 24, 2019 1:32 pm Post subject: |
| brian wrote: |
| Did you make the gasket yourself? |
yes I copied the external shape, and then I marked all the screw holes ..... then I created the inner edge with pc ..... the gasket has been cut with precision plotter, I have also created the water pump gasket because it no longer has any Piero |
Posted: Thu Apr 25, 2019 12:19 am Post subject: |
| Moreno wrote: |
| brian wrote: |
Very nice work _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Weed
Posted: Thu Apr 25, 2019 1:28 am Post subject: |
Nice result.
I'm afraid my hi tech knowledge on gasket making stopped with the ball peen hammer |
Posted: Thu Apr 25, 2019 1:32 am Post subject: |
| Weed wrote: |
Nice result.
Haha yep that’s about as technical as it gets with me too _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Moreno
Posted: Sat Apr 27, 2019 8:15 am Post subject: |
if I understood correctly this bike is for sale to single parts
Moreno
Posted: Thu May 09, 2019 6:42 pm Post subject: |
I decided to want to repair the spare twin fairings, in its most delicate points .... I used a thin metal plate 0.6 mm and I shaped it ready to be glued
Posted: Thu May 09, 2019 7:42 pm Post subject: |
If it were me, I would have reinforced it with fiberglass and filled the cracks with resin. _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Moreno
Posted: Thu May 09, 2019 9:42 pm Post subject: |
| I worked for a few years with racing motorboats and I learned to work with carbon, using fiberglass could be an alternative ...... I preferred the metal track to give it a more elegant look, I didn't want it to look like a normal fairings straight and repaired quickly .... the well-shaped metal workmanship gives a nice professional look to working on the fairings |
Posted: Fri May 10, 2019 8:01 am Post subject: |
| There is a company in Italy that makes fibreglass replacement panels...I've seen them and they are very good examples...come un painted....but it would stop the cracking...more "flexible" than the ages plastic that cracks....AND...they've redesigned the front end so that nasty thin strip of plastic that cracks and breaks under the headlight is no longer needed...Really though...Mr Caronni should be getting some more Carbon panels made up....they are also very nice |
Moreno
Posted: Fri May 10, 2019 8:08 am Post subject: |
| you know the motoflash fiberglass fairings .... I live near caronni tomorrow I go to find it to take a clutch drum ..... in a few months I will make fairing carbon from piero that has already done for his. ... |
