SB8R Fuel leakage on tank connection
dbtx
PostPosted: Wed Jul 22, 2026 6:19 am    Post subject: SB8R Fuel leakage on tank connection Reply with quote
Hi I am new to the Bimota world, with a SB8R in my garage since a few months
While plugging/ unplugging the fuel tank connection I noticed a small fuel leakage which stops after a few seconds but gives me little confidence that it would not cause any issues while riding
Is this a known problem and does changing the small gasket at the connector solve the issue? Or is there another way to fix this?
Thanks
David
atomibart
PostPosted: Sat Jul 25, 2026 8:41 pm    Post subject: Reply with quote
Hi David,
I guess you are talking about the plastic connexion ?
It does not age well due to the contact with the fuel.
Mine just broke while reconnecting it few years ago.
I had it replaced by a metal connexion and had no problem since then.
atomibart
dbtx
PostPosted: Tue Jul 28, 2026 8:39 am    Post subject: Reply with quote
Hi atomibart, thanks for your reply, yes my issue is with the plastic connexion - is there a specific reference for the metal one you are referring to ? Or would you have a photo of your new connection maybe ? Is this an easy job to replace / does it require some specific tools ?
Thanks very much
John KB1
PostPosted: Tue Jul 28, 2026 3:25 pm    Post subject: Reply with quote
And this metal connexion can't be found on the Suzuki TLR (or TLS) part-list?
It' s just an idea, but who knows?
John
atomibart
PostPosted: Tue Jul 28, 2026 6:35 pm    Post subject: Reply with quote
Hi David,
Actually I had it made by a friend who has Bimotas too.
Yes it requires specific tools. I will try to take pictures for you.
dbtx
PostPosted: Sun Sep 27, 2026 10:39 am    Post subject: Reply with quote
Finally I just changed the gasket on the connector to a new one, with a bit of silicone grease to ease the plugging and it’s now good
