BB1 Info - never even seen one before
MotoTipo99
PostPosted: Mon Dec 08, 2025 12:42 am    Post subject: BB1 Info - never even seen one before Reply with quote
Hello
Joined the forum as I'm thinking about viewing a BB1 which is pretty local to me, but I've never even seen one in the flesh and struggling to find much information on them online
https://www.carandclassic.com/l/C1816655
I know similar questions have been asked in the past and I have looked through older posts, but wanted to ask what to look out for, and what your ownership has been like in regards servicing, getting parts etc
For those who have had one would you recommend it, and do you still have yours?
I used to have an SZR660 - it was probably one of my favourite bikes to ride, but wasn't exactly a looker (never bothered me as the ride was so good). Am hoping the BB1 is at least as good to ride, but looks really lovely
If anyone has ridden both an SZR660 and a BB1 and could offer real life experience that would be perfect!
Basically any info you can be bothered typing would be appreciated Laughing
Anders
PostPosted: Mon Dec 08, 2025 11:14 am    Post subject: Reply with quote
I have only one Bimota; a BB1. I have owned it since 2001, I think. It is a very fun bike to ride. I cannot compare it to the SZR, as I have never ridden one, but I had an idea about buying one when they were new. The SZR is small for me, I couldn't get my kneed into the tank recesses.
However, back to the Bimota BB1.
I have ridden it a lot on trackdays and the like, and it also was my main street bike for years. I have modified it quite a bit, I think most of it is documented here or on my personal web site www.kvenna.net. That site is old and written in Norwegian, but I guess that is no problem in these days of automatic translations.
I have no idea of how many km it is used, I would guess 20- 30000 km. Most of these bikes gets ridden less.
The bike in your ad seems quite nice and also quite original. It is missing a few upgrades that I have on mine, like the fron fork compression and spring preload adjustment. These options are nice additions, at least the compression adjustment is good to have.
The main issue with these bikes might be the odd chainline. As you see in the images, the chain is quite slack. And it has to be, as it goes a lot tighter when the rear suspension is compressed. The engine sits so low in the frame compared to the swingarm pivot that the chain rubs the top chain slider away at a frightening rate. These chain sliders are one of the most common parts to replace frequently.
My solution is to use a much bigger front sprocket, 20t. It lifts the chain off the chain slider. In addition, I have a shorter primary gearing.
This is the most fun bike to ride that I have ever owned. It is also the most time-consuming bike to maintain, as even simple tasks like an oil and filter change takes much time. But that is all forgotten when the single cylinder barks out its sound and you are riding on twisty roads or on track.
It is not a bike for the longer trips, although I have ridden from Norway down to the Mosel valley on mine. Going stright ahead on the motorway is not what it was made for.
Its 48hp is not very impressing these days, but simple remedies like bigger carbs and a more open exhaust helps a lot. On mine, I have 2x38mm Dell'Ortos and a home made exhaust that still meets the 100dB limit on my local track.
I must admit my BB1 sits in the workshop these days, as I rarely ride on the street anymore. I'm now 65 and all my motorcycling is done on an endurobike in the woods and in enduro races.
I hope this helps. Go there and have a test ride! I think you will be hooked.
If you need more info, don't hesitate to ask.
Anders
MotoTipo99
PostPosted: Mon Dec 08, 2025 11:59 pm    Post subject: Reply with quote
Anders wrote:
I have only one Bimota...
Thanks very much for the detailed reply @Anders, really appreciate it
I've just read through the BB1 page on your website, really interesting read, thank you.
The thought of every job being a pain isn't ideal, ha, but it's something a bit special which I won't be doing mega miles, and not like I'll be relying on it to get to work. I guess with it having the Rotax engine with (having read your website!) lower power than originally intended, it won't have particularly short service intervals so should be fine.
They seem to have similar power to the SZR and I was always happy with that (even though I've ridden things with much more power - for UK roads you don't really need it, and with all the pot holes and speed cameras less is probably more!)
Thanks again - grateful for the reply
PostPosted: Thu Dec 11, 2025 11:13 am    Post subject: Reply with quote
I don't think the BB1 is special in terms of being a pain to work on TBH.
Bimota's are built for purpose and unfortunately that does not include maintenance . To get them compact everything has to be tightly packed , so you will have to remove 10 items just to get to the part you are after.
Like all Bimota's of the time the BB1 has a one piece fairing , the only good thing is the BB1 fuel tank is the belly pan so at least the fairing does not have to be splayed out to get past the front wheel.
Body work is obviously BB1 specific , so is quite difficult to find if missing/damaged.
Any of the Bimota specific running gear/ancillaries are possibly shared with other models of the era , so may be easier to find ( if anything bimota is easy to find Shocked ) but there is place like Bimota classic parts etc . Then there's the parts bin stuff that is off other bikes/donor bikes so you just need to find out what they are .
After you have got over all that , personally I love the looks of the BB1 , only ever ridden 1 once . Terrible bike round town but get it down a country lane and it was great fun , Would love to have a go on one with a bit more power . Very Happy
