Posted: Wed Jan 03, 2024 12:31 am Post subject: |
I bought a carbon bellypan from Perfect Fairings quite a few years ago too.
A better fix for the cracking front fairing would be to just buy a fibreglass front firing from Perfect Fairings too. The original tank/ seat unit is fibreglass so never an issue with that part.
I ended up finding a fibreglass half fairing in Italy which I’m going to use once I can get it painted. _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
mfennell
Posted: Wed Jan 03, 2024 5:32 pm Post subject: |
brian wrote: |
Hi Mike,
This is a great post. Nice info regarding the headlight. I’m in the process of looking for a headlight for my 2nd DB4 that I bought a few years ago with a lot of parts missing.
The fairing stay on my first DB4 also cracked and had to be repaired.
Thanks Brian!
You are spot-on that I should get the fiberglass bits from Perfect Fairings. My holdup is finding someone who can paint to match, getting stickers, etc. I might know a shop but I dread getting an estimate! I really should get them on hand regardless... _________________ Mike
db4, 848 Evo, 848, 701 Vitpilen, Aprilia RS250 |
Posted: Thu Jan 04, 2024 10:43 am Post subject: |
I agree... paint is the hold up for many of my projects!
I've recently purchased a full carbon fibre bodywork set from perfect fairings for my 2nd DB4. Not cheap but shipping from Greece to Australia was very reasonable considering it was a VERY large box. A little disappointed with the finish but kind of expected that as I've previously bought a carbon bellypan from them. _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
mfennell
Posted: Fri Jan 05, 2024 4:46 pm Post subject: |
Shipping to the US was only 35EUR. It was so cheap I thought it must have been an error and I was expecting an email that I owed more. The downside is that it was Black Hole Transportation once shipped. I eventually received notification that the box was in the US, then it randomly showed up some days later. _________________ Mike
mfennell
Posted: Sun Jan 07, 2024 6:41 pm Post subject: |
Pulled the horizontal head to replace the o-rings. Pleased by the lack of Bimota interference issues.
mfennell
Posted: Fri Jan 12, 2024 2:41 pm Post subject: |
Mostly buttoned back up. It's a little challenging to set the cables up with the FCRs so that they don't drag. Coincidentally, a friend had just bought a set for a very early Monster and we spent a couple hours messing with them and found it just impossible to get a satisfactory snap back. Sometimes it would stick wide open.
What I found on my bike that having enough slack on the pull side is critical. I single turn of the adjuster is the difference between a slow close when you release and a satisfactory SNAP while not having a sloppy throttle (which drives me nuts).
https://youtu.be/jvIzdW0Fz_4 _________________ Mike
mfennell
Posted: Sun Jan 14, 2024 8:34 pm Post subject: |
I wanted to take a quick spin yesterday. Pro tip: don't be thinking about the ride when you should be thinking about the work you're doing. I had been running it with an external fuel tank and forgot to switch the fuel on before installing the Bimota tank and putting the tank/seat cover. Helmet and gear on, warming the bike up, and ... dead. I cranked it for a while before I realized what I had done. I didn't have enough time to undo my mistake. Might be a while before I get it out because they'll be salting the roads soon.
A couple heat cycles and no oil leaking yet.
Someone posted to ducat.mi about cleaning up pipes with acidic toilet bowl cleaner and a scotchbrite so I had to to that since the pipe was right there and comes off in seconds.
[/img] _________________ Mike
