YB11 Purchased with 2800km What to Service?
NewBimotaYB11
PostPosted: Sun Jan 16, 2022 7:10 am    Post subject: YB11 Purchased with 2800km What to Service? Reply with quote
Hi All,
Just purchase a YB11 and need to know what needs to be serviced. The bike has 2800km and has only been around the block and had its brakefluid changed.
What needs to be done to keep it fresh. I will not ride it but for the trip around a longer block than before?
Peter
Thanks
P
Andrew034
PostPosted: Mon Jan 24, 2022 9:26 am    Post subject: Reply with quote
With 2800km it's low mileage for the age.
Personally I'd change all fluids:
Oil and filter
Coolant
Fuel
Brake and clutch
If you're keen
Forks and rear shock too
Additionally I would normally change the spark plugs.
If the fuel is OK the filter can be left, but you may consider it too
I'd check the air filter, but it should be OK.
If the tyres are over 3 - 5 years change them to
Check the chain tension and also lube it.
Check the brakes, they should be OK but expect some rust and maybe they will need rebedding in.
Normally I'd also add some cleaner to the fuel to clear the carburettors, I've had poor running after a long sleep.
Also expect some leaks during initial riding, so check the bike carefully during initial usage - forks can be problematic as can fuel connectors.
Andrew...
PostPosted: Tue Jan 25, 2022 1:00 am    Post subject: Reply with quote
If it's been sitting for a while, the carbs will need a strip and clean. Even if the float bowls were drained when it was parked up, the residual fuel in the carb internals turns to shit. A complete strip and ultrasonic clean is the best way.
NewBimotaYB11
PostPosted: Sun Jan 30, 2022 1:44 am    Post subject: Reply with quote
Thank you!
P
Thanks
P
